Old 06-22-2005, 10:09 AM
455Turbo's Avatar
455Turbo 455Turbo is offline
I drove 35 miles to the chassis dyno yesterday and put down 730 RWHP. This was on 110 octane fuel with open pipes. Last year it made about 600 RWHP on pump gas and ran a 10.58 sec quarter mile. I should have new quarter mile times in a few weeks.
Some specs:
463 cubic inches
two T04B 60-1 turbos
Water/Air intercooler
FAST fuel injection
Victor intake
Eagle rods
custom JE pistons
steel 4-bolt mains
Twin Turbo Trans Am - 9.64 sec @ 148.51 mph, 3870 lbs.
Old 06-22-2005, 10:10 AM
455Turbo's Avatar
Another pic
Old 06-22-2005, 10:14 AM
Chris Petersen's Avatar
Chris Petersen Chris Petersen is offline
Send a message via MSN to Chris Petersen
Aewsome #'s!
I love the look of that setup.
463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO!
Old 06-22-2005, 10:20 AM
That is great!
Old 06-22-2005, 10:28 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
what year firebird 77-81???
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 06-22-2005, 10:29 AM
Fascinating upper-hose route.
Fascinating Air cooler.
What Heads & Piston dish?
Old 06-22-2005, 10:31 AM
76TA428 76TA428 is offline
That is one of the most impressive turbo setups I have ever seen. Happen to have any more pictures with closer detail?
1979 Trans Am
1969 428
Old 06-22-2005, 10:53 AM
dutch injun's Avatar
dutch injun dutch injun is offline
Awesome. I love that radiator hose!
Old 06-22-2005, 10:57 AM
"Guy
WHERE CAN WE GET ONE?
You are quite a fabricator! The exhaust manifolds and the inner cooler look wicked.
Old 06-22-2005, 12:04 PM
Silver Judge's Avatar
Holy Crap !
What a stout set up, over 700 hp at the wheels !
Bet it sounds downright evil
Like others said, the fabrication work looks great.
Do you have FAA approval ?
501 HP, 554 ft lbs TQ
Old 06-22-2005, 12:14 PM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
That's is SWEETTTTTTTTTTTTTTTTT !!!
Old 06-22-2005, 12:25 PM
fast72lemans's Avatar
fast72lemans fast72lemans is offline
Send a message via MSN to fast72lemans
Great numbers, should be a wild ride!!!!
Old 06-22-2005, 12:40 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Awesome ride--very nice--Trans Am Kahuna was planning to build something like that for the http://www.silverstateclassic.com .
Old 06-22-2005, 01:36 PM
firechicken's Avatar
firechicken firechicken is offline
Quite an improvement for sure. Looks like the 60-1s did the trick. You kept your same turbines correct? At what psi did you make those numbers? How much torque?
Old 06-22-2005, 06:36 PM
Great Job, Glad the 60-1s worked like I hoped they would.
Awesome installation too. That looks like a serious water to air deal you have there.
What bricks did you use?
Old 06-22-2005, 07:54 PM
critter's Avatar
critter critter is offline
OK, what color are you painting the car? I want to know who NOT to pick on at the stop light.
Way cool.
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 06-22-2005, 08:23 PM
69v8tr6 69v8tr6 is offline
Awesome power numbers. What heads and what were the boost numbers, RPM's?
What are the cam specs?
Old 06-22-2005, 09:24 PM
ponchospidel's Avatar
ponchospidel ponchospidel is offline
excelent job!
1973 ventura pump gas street car [email protected]/ [email protected], 3645#
1968 procharged firebird 5.66@123mph 1/8mile-F-2(22#boost), CSU E-85 carb, 477 IA2, 315cfm Butler E-heads, and factory suspension, 3580#. 939RWHP@25#boost
thanks to Butler Performance, CSU carbs, and All Pontiac.
Old 06-22-2005, 11:22 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Nice numbers, its good to see someone pull off the twin turbo set up that they made!!
Since you did a lot of the mock up yourself you should considering making that setup along with a single turbo set up on the passenger side. I am sure after seeing your numbers guys will come around to doing turbos.
What size injectors are you running?
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 06-23-2005, 02:08 AM
grandville455's Avatar
That sure is puurrrrty .....Awesome numbers too by the way!!!!!!!!!!!
Darby
M/T 275/60 ET SS Drag Radial
