Old 07-15-2005, 05:21 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
I'm going to have to buy another front carpet at some point because the new boot couldn't quite cover the old hole completely.
_________________________
Sonny Barger
Old 07-15-2005, 05:22 PM
6567GTO's Avatar
one more...
Sonny Barger
Old 07-15-2005, 05:23 PM
culick culick is offline
Hey, great job!
It looks like you are using a Lakewood bellhousing. How well was the center and parallel alignment? Did you have to use offset dowels?
I just indexed my Lakewood (I'm putting a tko 600 in my 69 firebird) and it was right on: 0.002" runout on center bore, and 0.0015" off parallel.
Old 07-15-2005, 05:28 PM
cwolf cwolf is offline
Send a message via Yahoo to cwolf
that looks real good maybe one day for myself
Old 07-15-2005, 05:29 PM
6567GTO's Avatar
The Break-In & Test Drive
After everything was put back together I started the car up while still on the jack stands to run it for 15 minutesfor the intitial break-in. During that time I sat in the car and went through all the gears and also let it run each gear for a few minutes at a high idle. After that was done I dropped the car back on the ground and took it for a ride. I immediately noticed a big difference with the first gea ratio. My Super Case muncie had a 2.20 ratio and the new TKO has a 2.87.
My car has 3.73's in the rear and I didn't realise till now how much better a lower ratio in first could make. After a couple hundred miles of driving time all I can say is I LOVE IT!!!!!
I can actually drive down the highway again going 70 mph with my engine revving at about 2,000 rpm's.
Can't wait to take it to the track! I'm hoping that I'll have better 60' times which should help my overall ET as well.
If you're in the market for a 5 speed trans like this TKO600 give Jeff or Scott at Classic Chevy 5 Speed a call or shoot them an email. I forgot to mention that when I called a couple other plces that sold Tremecs they told me it would be at least 6 weeks before they could ship me a trans, Classic Chevy 5 Speed had them in stock!
http://www.classicchevy5speed.com/
(760)230-2045
Sonny Barger
Old 07-15-2005, 05:34 PM
Cool A Big Grin Factor
Old 07-15-2005, 05:42 PM
6567GTO's Avatar
My bell housing alignment was about the same culick. Didn't have to change a thing! Good luck with your Tremec install. If there's any question I can help you with shoot me an email.
Phil
Sonny Barger
Old 07-15-2005, 07:23 PM
John Payne's Avatar
John Payne John Payne is offline
Thanks for those helpful pics Phil..you did a great job.
65 GTO 4 spd Tri-power Convert 13.64 @ 104.94 2.23 60' 3920# bias ply tires
Old 07-15-2005, 07:44 PM
mwritter's Avatar
mwritter mwritter is offline
I REALLY want to do this swap...I just wish things looked a little more stock inside.
Matt
1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor
1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD
1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring|
1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners
2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD
2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles
Old 07-15-2005, 08:03 PM
6567GTO's Avatar
Actually mwritter, if you bolt a more like stock shifter arm in place of the shorty I used it will look more like stock. And like I said in one of the posts I can use my console with the offset shifter that I chose. With a console in place I doubt you could tell the difference. I just went the other route for now.
Thanks John! I'm real happy with how it came out. The tunneling doesn't look any different with the carpet in place. I basically raised it about an inch.
Sonny Barger
Old 07-15-2005, 08:12 PM
Hooter's Avatar
Hooter Hooter is offline
Phil - Did you check with Kessler(I think that's the right name) about one of their kits? When I redo my 62 Cat, plan on a 421 with this same transmission. Just curious if there was much difference between the 2(in the event you talked to them).
67 Bonneville ragtop
Old 07-15-2005, 09:18 PM
6567GTO's Avatar
Yes I did Hooter. They were one of the ones that told me 6 weeks delivery for the trans. My car needed a trans now and Classic Chevy delivered. Keisler is good but they're not the only one out there.
Sonny Barger
Old 07-15-2005, 09:59 PM
jeffmort jeffmort is offline
Phil-
Good job and good info on your install. I am glad to hear that you like the transmission.
Keep us posted.
Jeff Mortenson
Hurst Driveline Conversions
www.hurst-drivelines.com
760-438-2244 (ext. 103)
[email protected]
"Specializing in Tremec TKO & T56 Magnum overdrive conversion kits for Pontiacs"
"Number 1 in Customer Service & Support!"
Old 07-16-2005, 12:03 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Clean install, nice car! Always liked red on '65s.
For those of you that want an OD transmission but aren't up to modifying your car's floor, there's a new richmond 6speed available in the for sale section.
Old 07-16-2005, 08:22 AM
Junkyard Dog's Avatar
Did you end up using their yoke with the 1330 U-joint?
Badder than old King Kong
-Jim Croce
Old 07-16-2005, 08:23 AM
Jeff, are there any plans to release a yoke with a 1350 u joint?
-Jim Croce
Old 07-16-2005, 09:13 AM
6567GTO's Avatar
JYD - I did go with the 1350 u-joint on the front but honestly can't remember what we did for the back. I have a less common rear end yoke on my 12 bolt. I went as HD as I could. I'll have to check my records.
Sonny Barger
  #38
Old 07-16-2005, 09:26 AM
SGTGTO's Avatar
SGTGTO SGTGTO is offline
Send a message via AIM to SGTGTO
I second CC5speed! Those guys are great. I got the wrong speedo gear when I bought it. I installed it and ran it months later and noticed it. They had one shipped out that day for me, free of charge. They really go out of their way there.
6567- Just wait a few hundred more miles. The shifts just get smoother and smoother. Its like butter in mine. That 4-5 shift takes a little bit of getting used to though.
Saving the world... One country at a time.
  #39
Old 07-16-2005, 09:30 AM
A 1350 yoke is already avaialble and is a common part. Actually we have 1350 yokes in a solid Spicer style1 or a custom quick release version. You just need to request which one you want when your driveshaft is being built.
Phil has a 1350 slip yoke and 1350 ujoint up front and has a "3R" style (not to common)ujoint in the back.
For the most part you will find 1310 ujoints as stock (sometimes a 1330). With that said, you can choose whicever size you want (1310, 1330, 1350). Of course you will need to change your rear pinion yoke to match your rear ujoint.
Jeff Mortenson
[email protected]
  #40
Old 07-16-2005, 10:01 AM
Tom McQueen Tom McQueen is offline
I like my TKO-600 more everytime I drive my car. One of the best mods I did. But I do have a question. Which offset shifter are you using? I am aware of only one. I put an offset shifter on mine, and it didnt last 100 miles. The entire shifting force went thru a very small drift pin. When the drift pin broke, it stranded me and I had to be tow trucked home. I am modifying my console so I can use a standard shifter.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
