Old 09-29-2004, 06:44 PM
tom8461 tom8461 is offline
In the process of fixing up a 79 TA. Discovered a power opener button on the glovebox. Any clues as to where to begin looking for a gorond or hot wire to make this thing work..Thanks in advance...GREAT site BTW
Old 09-29-2004, 07:20 PM
GA Dave GA Dave is offline
I looked at a wiring diagram. The line to the switch should be an 18 guage orange wire. Teh switch probably grounds itself. Couldn't find the colors for the release. They should be obvious.
If you are just trying to get it to work, any hotwire should work. Preferably one that is only hot with the key switched on.
David
Old 09-29-2004, 07:42 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Orange or red wire plugs into the fuse box goes over to the switch. Then a black wire connects to the other terminal on the switch and runs to the back of the car to the solenoid mounted on the trunk lid latch. The solenoid grounds out through the body of the car.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 09-30-2004, 08:05 AM
My 81 someone had used the black wire to a common ground for the stereo! Had to trace it from the trunk up and splice in for the hot wire.
Old 10-02-2004, 12:57 AM
Brutus_5150 Brutus_5150 is offline
I could be mistaken, but the latch/solenoid grounds from the trunk lid itself, with one wire leading from the trunk to the switch input, and the output lead goes to the cig lighter or the fuse panel. Whatever Dennis said.
Old 10-02-2004, 01:11 AM
Dens71TA's Avatar
The latch solenoid grounds to the body though the same bolts that mount the trunk latch assembly. The latch is on the rear tail light panel on F-bodies. Grand Prix's used the same latch/solenoid setup but it was mounted on the trunk lid so maybe thats what you are thinking of.
Power connector simply plugs onto the fuse block with a female/male blade connector. The power trunk release is a REALLY simple circuit and is easy to add.
Old 10-02-2004, 03:55 PM
SlinkyBMX's Avatar
SlinkyBMX SlinkyBMX is offline
I'm just curious, did 79's have the option for this? I seen a 80 Firebird at the junkyard yesterday with it, and I am very tempted to borrow this
1979 Trans Am SE 301/Auto - Soon to be 455/4-speed
Old 10-02-2004, 09:16 PM
CoolBird CoolBird is offline
77-up had the remote deck lid release. The UPC code was A90.
77 Y81 4-spd 42K Survivor
77 Y81 4-spd Clone
Old 10-03-2004, 10:43 AM
Dens71TA's Avatar
Actually the remote decklid release was available right from the begining of the 2nd-gen in 1970.
