Old 12-16-2003, 03:42 PM
70L34 70L34 is offline
Hey everyone,
I pulled the original 3.23 10-bolt safe-t-track out of my '65 in preparation to sell it (replaced with a 12 bolt). I can't find any of the two-letter codes stamped on the rear, only a "P 3.23" stamped on the backside of the passenger axle tube. Any ideas? Can I tell if this is a 2 or 4 pinion posi without pulling the cover?
Thanks,
Tony
Hey everyone,
Thanks,
Tony
Old 12-16-2003, 05:28 PM
Glenn Glenn is offline
On Vacation
A 3.23 non Safe-T-Track rear end code is WF and YF with Safe-T-Track. If you don't have a code stamped on the passenger side of the axle tube it sounds like it isn't the original rearend, so its anyone guess. Non safe-T-Track rearends codes in '65 start with W or X. Safe-T-Track start with Y or Z.
Old 12-16-2003, 08:08 PM
Greg J Greg J is offline
The code you identified sounds like a 64 code to me. If it is an early car, it could have received a 64 rear from the factory. As far as 2 or 4 pinion, I doubt that with the 3:23 it would be a 4 pinion.
Old 12-16-2003, 08:48 PM
On Vacation
Greg
Thats a possiblity, but in '64 the P code was a 3.90 ratio and had a green paint color. The 3.23 ratio was either L or M with a brown or green/brown paint color. An additional X would indicate Safe-T-Track.
Old 12-17-2003, 06:10 AM
gto65 gto65 is offline
MY 65 GTO WAS BUILT LATE 64 AND IS A 46K MILE BOLT UNTURNED CAR.
THERE IS NO CODE STAMPED ON PASS SIDE HOUSING
HOPE THIS HELPS
THANKS JIM
Old 12-19-2003, 03:11 PM
Mikelav418 Mikelav418 is offline
I know that this is absolutely no help to you, but my 65 Tempest has the exact same stamp where the code is supposed to be located. Mike
Old 01-21-2004, 06:25 PM
mhgamber mhgamber is offline
Hey tony I have a 2.78 open rear that has stamped letters (cant remember what) it may be from a 64. Can you give me more info on your 12 bolt swap? Have you sold the 3.23? That is the ratio I was considering. You can email me at [email protected]. Thanks, Mike
