Old 07-15-2003, 03:03 PM
lampoon's Avatar
lampoon lampoon is offline
Ok. I have the gastank off. To remove the sending unit do I tap it out? Or is there some twist trick? What tool do I use? I cant remember. Anyone know where to get replacement padding that goes on top of the tank between it and the trunk?
1965 GTO Convertible, Blue Mist Slate.
1967 GTO Hard Top Coupe, Champagne Gold
2005 G6 Sedan, Electric Blue
lampoon's Avatar
Old 07-15-2003, 03:18 PM
1970cat's Avatar
1970cat 1970cat is offline
should be a notched lock ring , put a screwdriver against the tab and tap it until it spins and unlocks
Old 07-15-2003, 04:43 PM
Brad B. Hillebrand's Avatar
Brad B. Hillebrand Brad B. Hillebrand is offline
Ditto 1970Cat...
Take a ride in my Twin Turbo 63 Lemans.......
http://www.youtube.com/watch?v=Ad8g9IfWxKI
Hot Rod Cover Car -April '07
PHR Magazine Sept.'08
1244HP Pump Gas Dyno @ 11psi (32PSI MAX)
http://s297.photobucket.com/albums/m...ipumpgas-2.flv
Old 07-16-2003, 03:28 AM
lampoon's Avatar
Any idea about the padding?
Old 07-16-2003, 07:41 AM
stevek0629 stevek0629 is offline
I got my tank pad from PY, part number RPR71S for $22.00
Steve
Old 07-16-2003, 08:28 AM
lampoon's Avatar
Thanks Steve. I just ordered it. When I get home I will attempt to tap out the sending unit.
Does PY sell replacement socks or is that something any auto part store carries?
Old 07-19-2003, 06:03 PM
lampoon's Avatar
I cant find a replacement sock anywhere. I will add an inline filter before the pump but I'd like the sock as well. Ive read several; posts about AC Delco socks. The parts places around me say "discontinued" when I inquire. Ideas?
Old 07-19-2003, 06:39 PM
goatseeker's Avatar
goatseeker goatseeker is offline
PY and Ames both carry replacement A/C Delco socks and pre-assembled socks on their complete sending units. For '66 the stock pickup tube is 5/16" - the replacement is 3/8" but it works fine. There is some difference in the sending units between A/C and non-A/C cars so make sure you get the correct one for your application.
Tim
http://kurtspontiac.homestead.com/TimSimpson66GTO.html
Old 07-20-2003, 04:34 AM
lampoon's Avatar
I still cant find the replacement socks. It wont come up under any searches. Do you have a PY part number???
Old 07-20-2003, 04:54 AM
lampoon's Avatar
Tim....how did the 3/8" fit on the 5/16"?
Does it cinch down with a metal wire or something?
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by goatseeker:
Tim
http://kurtspontiac.homestead.com/Ti...></BLOCKQUOTE>
Old 07-21-2003, 09:42 AM
engineer engineer is offline
don't do a search, just open the paper catalog and order it. It is still available at the auto stores and at the ford dealers as well.
