Old 11-13-2004, 10:09 PM
az67goat's Avatar
az67goat az67goat is offline
Will a 1000 lbs capacity stand ($39) work fine for holding my 400 or should I spend twice as much ($79) for a 2000 lbs capacity unit?
az67goat's Avatar
Old 11-13-2004, 10:13 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
i used a 39 dollar harbor freight 1000 lb special for my 400 and didnt have any problems. cast iron heads, cast iron intake etc.
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 11-13-2004, 10:59 PM
66poncho455 66poncho455 is offline
I'd spend the money on the holding bolts. Get the highest Point possible. When your looking at the top, count the number of lines from the center pointing outward. The more lines the better. I believe it's number of lines plus 2. So if you see 5 lines on the head, it's a seven bolt (which is good...) The stand is typically fine, what snaps in usually the bolt ( I've heard...) Good luck
"In my house I'm the boss, my wife is just the decision maker."
Old 11-14-2004, 12:57 AM
greyno3's Avatar
greyno3 greyno3 is offline
GET a 4 wheel stand. they're more sturdy than a 3 wheel stand. A 1000 lb. stand should be fine.
greg
10C 1972 Formula 461 non A/C
08B 1969 GP J/428 non A/C
Old 11-24-2004, 05:08 PM
68Redbird 68Redbird is offline
I used a 750 pound one when rebuilding my 455. It sagged when I added the heads and accessories but it held up.
68Redbird
Old 11-24-2004, 05:55 PM
runningbwdog's Avatar
runningbwdog runningbwdog is offline
Hi,
I bought the 1000 lb one from Harbor Freight.
I got grade 8 bolts and double washers.
The arms that bolt to the back of the eingine may bend a little. It is hard to move around on the wheels that it came with and the tuning tube is hard to move with a fully assembled engine on it.
Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels
Old 11-24-2004, 09:40 PM
az67goat's Avatar
Thanks Mike!
Old 11-24-2004, 09:43 PM
BVR421's Avatar
BVR421 BVR421 is offline
forget the rating, get anything with -4- wheels much more stable than the -3- wheel
