Old 12-11-2003, 08:42 AM
goatman64 goatman64 is offline
My thanks to all who have helped me thus far...I'm getting close but yet another question.
Just installed new weatherstrip...the new roofrail stripping now does not allow enough clearance for the 1/4 window to roll up (too much contact at the lower rear of the window). This is definitly the only hanging point as I took the stripping loose and the window rolls up. Is there an adjustment for the window? Can't see any that is evident. Thanks again in advance.
Old 12-11-2003, 05:28 PM
merlin merlin is offline
Goatman, Yes ther is. Remove the panel and on the window mechanics you will find four adjustments that will let you move the window up, down, foward, and backward.It will be a hold down nut on a slot, once yoy loosen the nut then you can slide the window track. It is much like the adjustment on your alternator.Hope I helped you. Merlin
Old 12-12-2003, 09:38 AM
Merlin...thanks alot, nothing I've tried has worked thus far...I'll give it a look later today.
Old 12-12-2003, 11:57 AM
engineer engineer is offline
the body service manual shows all the adjustment points and discription about what to adjust to move the window where you want it.
Old 12-12-2003, 11:21 PM
Thanks all...I had been looking inside the window housing for the adjustments. Mine still had some sort of hard putty covering all but one of the adjustment nuts that I had to pry off to access. Got it taken care of and put back togerther...thanks.
