Old 11-08-2001, 08:22 PM
UnchainedGTO's Avatar
UnchainedGTO UnchainedGTO is offline
Does anyone know of a web site or book that has the flow numbers for various stock Pontiac heads. In particular I am looking for the numbers for 1968 #16 heads on my 400.
Thanks,
Unchained
Thank you,
Don
1963 Lemans
1965 Catalina 2+2
1968 GTO
1969 Lemans OHC6
1972 Formula
1974 GTO
1986 Grand Prix 2+2
1986 Fiero SE
2005 Bonneville GXP
Thanks,
Unchained
Thank you,
Don
1963 Lemans
1965 Catalina 2+2
1968 GTO
1969 Lemans OHC6
1972 Formula
1974 GTO
1986 Grand Prix 2+2
1986 Fiero SE
2005 Bonneville GXP
Old 11-08-2001, 08:44 PM
Goatman Goatman is offline
On Vacation
Almost all the D-ports flow within a couple CFM of each other. I would say around 185+- CFM on the intakes.
Old 11-09-2001, 12:04 AM
WDCreech's Avatar
WDCreech WDCreech is offline
Try the April 1991 issue of HPP.
Bill
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 11-09-2001, 08:28 AM
Larry Navarro's Avatar
heres the site you need....... http://www.pontiacwarriors.com/
Old 11-09-2001, 09:37 AM
455ho 455ho is offline
Try this link. I think it's the article that WDCreech is talking about:
http://clickit.go2net.com/adclick?ci...eddedexitpopup
Old 11-09-2001, 09:43 AM
Sorry, wrong link......don't know where that came from? Try this one:
http://www.pontiacpower.org/ultimateflow.htm
Old 11-09-2001, 11:34 AM
76TA 76TA is offline
Keep in mind that these numbers are flowed at 12 in. hg. Is there a reliable conversion factor to 28 in. hg ?
Old 11-09-2001, 11:43 AM
The above flowbench tests should be interpretted as a comparison of the heads that were analysed at the time. They were originally tested at 12". Conversion of these figures to 28", & subsequent comparison will have some scratching their heads, wondering "what if" all of the heads tested had been tested in #1 shape.
If your heads are ones that were shown as #2 condition or #3 condition (the '71 HO's) in the above tests... might do as I did, & pay to have several sets of near identical #1 condition heads flowed on a Superflow 600 at 28", you will get a far more accurate result.
Old 11-09-2001, 11:46 AM
76 T/A,
The conversion factor that was used in the "for beginner's" simulated dyno test was 1.2333
Old 11-09-2001, 09:41 PM
zedo zedo is offline
On Vacation
Unchained, I flowed a few pair of stock D-ports at 28" on a Superflow 600. The intakes flowed 210 cfm, the exhausts flowed 160 cfm.
Old 11-10-2001, 12:07 AM
Thank all of you for the information. I have been able to find the information needed from your responses.
Unchained
Thank you,
Don
1963 Lemans
1965 Catalina 2+2
1968 GTO
1969 Lemans OHC6
1972 Formula
1974 GTO
1986 Grand Prix 2+2
1986 Fiero SE
2005 Bonneville GXP
Old 11-11-2001, 12:47 PM
As they said above that article in HPP is good for comparisons of those heads tested. ven converting their 12" numbers come no where close to any numbers I have even gotten.
Old 11-11-2001, 08:26 PM
On Vacation
Conversions from 12" HG are inaccurate. If you want useable flow figures, it should be done at 28" HG. That's where a V-8 engine spends most of it's time while actually running- and that's the figure most shops insist on using for the past 20 years.
