Old 01-04-2003, 02:56 PM
jcruz's Avatar
jcruz jcruz is offline
Another mystery part, at least for me. This is hanging off the radiator core in front of the radiator. The line looks like it connects back to the transmission.
It's a 69 Firebird non-air automatic.....
Thanks,
John
1969 Firebird resto...doing my part to keep PY profitable....
69 Firebird/TA clone
jcruz's Avatar
Thanks,
John
Old 01-04-2003, 03:05 PM
Aftermarket tranny cooler.
Let's go racing!
www.outlawpontiacs.com/members/B-Man2.php
www.outlawpontiacs.com/members/B-Man.php
Old 01-04-2003, 04:54 PM
jcruz's Avatar
I'm going to demonstrate my utter ignorance here...have mercy....
I'm guessing tranny coolers are only for an automatic transmission??
My project car had/will have a manual transmission and the one pictured is an automatic. I'm transplanting the 350 but not taking the tranny. In that case, the cooler wouldn't be needed, right?
Thanks,
John
Old 01-04-2003, 05:06 PM
Bob25 Bob25 is offline
Thats right, you will not need the aftermarket cooler for a standard transmission car.
1969 Pontiac Firebird Convertible
Old 01-04-2003, 11:01 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Yep! Aftermarket tranny oil cooler. With a manual transmission, the heat generated by the coupling the drivetrain (dumping the clutch) is transfered from the clutch friction disks and flywheel to the surrounding air via convection.
With an automatic transmission, there is no solid mechanical link between the engines crank shaft and the drive shaft. Torque is transmitted thru the torque convertor via the transmission oil itself. I know it sound wierd but the transmission fluid is directed by a stator and constantly sheared between impellor and turbine wheels in the convertor. The impellor blade (connected to the flexplate) rotates at engine speed and forces the transmission fluid thru several directional vanes. These directional vanes dischare the tranny fluid onto the leading edge of the turbine blades. The inertia and shearing forces of the discharged fluid turn the turbine blade and the rest of the transmission. This constant shearing produces heat which must be dissipated. Therefore, a transmission oil cooler must be used to prevent overheating.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 01-05-2003, 09:12 AM
jcruz's Avatar
Good info!
It'll be going in the trash when I move the motor!
Thanks a bunch,
John
Old 01-05-2003, 02:45 PM
mar3 mar3 is offline
Yipes! And I thought I had a lot of work ahead of me on the CBird! You have inspired me to get out there with that shot, sir! Thank you!
1968 P/S coupe
1968 convertible
1968 Firebird convertible
1968 Firebird Pro-Street coupe
1984 Mazda RX-7 GS...sidelined DC Solar yellow, 'bout to go 2+2...
1983 Mazda RX-7 GS...8100 rpm corner carver, 2300 lbs, 'new' DD
Old 01-05-2003, 03:10 PM
jcruz's Avatar
Mar3,
If you only knew....that's nothing!
But, I've been at it over a year now and I haven't found anything yet I can't tackle without some planning, some $$, and the right tools.
John
