Old 03-31-2003, 07:44 PM
trim trim is offline
Does anyone make a base/clear system that I can spray in my garage and not have to use a clean air system? I would really like to do the epoxy primer and surfacer without having to rent a respirator. If everything could go on with just a charcoal filter mask, that would be great.
Old 04-01-2003, 04:15 AM
A1Judge's Avatar
A1Judge A1Judge is offline
I don't think so. All 2K paint systems usually have ISOs in them as that is the catalyst that hardens the paint.
I bought a fresh air mask, $79, and used my smaller old oil-less compressor to feed it. I had a HEPA filter on the intake and exhaust of the compressor, added a valve to control the amount of air it fed the mask, and ran it outside the garage, away from any fumes.
Worked like a champ.
Don
restored a 70 Judge at: http://home.rochester.rr.com/dchapman
My 70 Judge Restoration documented at: http://thejudge.dyndns-home.com:8080/
Old 04-02-2003, 07:54 PM
irgoatmike irgoatmike is offline
Hey Trim, Most non-iso products went by the wayside some time ago. (Durability issues) A couple of ways to cut down on exposure are to use an HVLP spraygun,(65% transfer eff. vs. 35-8% Conv. guns.) Cover your skin well, and increase air flow through your garage. The last one will also help you avoid solvent drop and a less than glossy clear. Neighbors and bugs could be a problem. Just some of my thoughts and input. Good spraying! irgoatmike
Old 04-02-2003, 08:58 PM
Thanks for the response. I will start working on a fresh air supply...
Old 04-10-2003, 08:52 AM
Nickv's Avatar
Nickv Nickv is offline
Dupont is working or has already a non-isocyanate paint called 50P POLYACRYL ANHYRIDE ENAMEL. Don't know if it's available or what the applications are. But it is to answer those who want a 2 part paint that does not contain isocyanate's.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecargalore.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger Scat Pack 392, 6 speed
2021 Ford Explorer
Old 04-10-2003, 12:09 PM
llucas llucas is offline
Try here: Dupont
