Old 05-04-2005, 02:31 AM
LeighP's Avatar
LeighP LeighP is offline
A 403 top will fit on a Pontiac base....I know, I'm using one on my car. The scoop top has to be repositioned on the 403 adapter ring, but it'll clear under the skin of the stock hood (just)...I tried it. I'm currently using a Formula hood with the shaker hole cut into it...works perfectly for that application too.
You need to use the 403 clamp (the Pontiac clamps a bit small). The actual difference in diameter between the adapter and the base is only slight and doesn't seem to make any difference to the clamping force when the ring is tightened up.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
