3 possibilities:
1. Starter is mounted to a painted block pad. Overall starter case assy, GND path & wiring experiencing a resistive path. 2. Duh yea, internal slug-wall friction gone high when warm...put a torque wrench onto the harmonic balancer, or if your "feeling lucky" grab the balancer pulley by hand and see if you can turn the assy by hand cold, then hot. I do this on my assys (takes grip, concentration and technique ( I pull the Left-side V-belt too, push the right side down) 3. Bearing damage in crank,cam, maybe rods. take your pick...I had #3 occur because I puts STD bearings on a .010 crank...you'd never dooo thaaat right.
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
