Old 08-02-2002, 10:25 AM
Philcol Philcol is offline
Which cam? Street engine.
79 T/a
400 (.060 over)
4 speed, 24# flywheel
3.42 rear
9.5 comp.
performer manifold
headers
Comp cams XE268 or 280 H or RA4?
Thanks,
Phil
"dreamed I was wide awake........woke up and I was sound asleep"
79 T/a
400 (.060 over)
3.42 rear
9.5 comp.
performer manifold
headers
Thanks,
Phil
Old 08-02-2002, 02:04 PM
RPM's Avatar
RPM RPM is offline
Send a message via Skype™ to RPM
I'd say the XE268 is the best choice of the three you listed. Crower has some nice grinds too. I think something along the lines of a 214-216ish intake duration with 8 degrees more exhaust on a 112 lobe sep would be a very nice street cam.
Old 08-02-2002, 02:10 PM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
Far from an expert, but the Summit 2801 seems like it would be a good choice. $57 bucks too !
Specifications:
* Advertised duration: 272 intake/282 exhaust
* Duration at .050 in. cam lift: 214 intake/224 exhaust
* Gross valve lift: .442 in. intake/.465 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 2,000 to 4,500
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
Old 08-02-2002, 03:00 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Crower 60916 (221/220, .450/.470, 112 LCA). Used this cam in three medium compression 400's this year with 1.65 HS rockers. Decent idle, strong mid-range and top end power. Took on of the cars (66 GTO) to a test and tune last tuesday. In street trim with 2.05-2.25 60' times it ran 13.30's at 104mph, easily a 12 second car with good traction. Last year I tried the XE268 in a 400 with #16 heads and was not pleased with the results......Cliff
Old 08-05-2002, 08:55 PM
Jason Wier Jason Wier is offline
I ran a compcams 282 solid cam in my 400 in a 79 10th Ann. TA. 236/236 at .050 with 1.5 rockers on the intake and 1.65 on the exhaust. With 8.5 to 1 compresson home ported "96" d-port heads and performer rpm intake, RA III exhaust manifolds. It would run 13.1-13.3 at 106-107mph with 2.2-2.3 60 footers. I thought it was a great cam.
Old 08-06-2002, 12:07 PM
GTOPhil GTOPhil is offline
Cliff R. has a great suggestion. Also, the UD 221/230 that I run is a great cam in a medium compression motor.
Old 08-06-2002, 12:22 PM
AG's Avatar
AG AG is offline
Go with GTOPhils recommendation for more power than stock or the RAIV with Rhoads lifters for a fairly hot 400. My '65 GTO 3858# with 3.55 rear, 2500 rpm convertor did 12.70 going through the traps at 4900 rpm with a performer intake and RAIV cam
Old 08-06-2002, 08:49 PM
rand68 rand68 is offline
<font size="2" face="Verdana, Helvetica, sans-serif">Cliff, what kind of drivetrain do you have behind that cam? I had a 60243 at one point, and it was too high of an RPM band for my auto/stock converter/3.08 gears. I was looking at the 60240, or 60241 for my next street engine (pure street, no racing).
Thanks!
Bill
Old 08-07-2002, 07:17 PM
Cliff R's Avatar
Bill, the drivetrain consists of a TH400 with the best of everything, Continental 10" "Jim Hand" converter, 8.2 10 bolt with 3.73 gears. The engines uses well prepared #62 heads with exhaust crossovers filled, stock cast rods, zero deck TRW forgings, balanced, RPM intake, 800cfm q-jet, 4 tube headers, Crower 60916 cam set at 110 ICL, HS 1.65 roller rockers. Idles with noticable lope, strong power from right off idle to the shift point. The goal was to build an affordable combination mild enough for daily use and still run well at the track on occassion. This is easily done with the 455's and they seem to get all the attention these days. So far we are very pleased with the results, the owner also reports very good fuel economy and no problems running pump fuel even in this BRUTAL heat.....Cliff
