Old 06-26-2002, 11:35 PM
sdavis sdavis is offline
I have a 69 GTO with headers and turbo 400. I replaced the starter with an after market high torque gear reduction starter. I have replaced the flex plate with TCI heavy duty plate and converter. Sometimes when I engage the starter the bendix gear will hit the flex plate and will not engage to spin the motor. When this happins, if I move the flex plate an inch or so it will engage and start. Other times it engages and starts fine. I have tried starter shims but I can't get this problem to stop. Someone please give me some help!! This is very frustrating.
Old 07-04-2002, 01:21 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
I'd return the unit, take the original starter to a shop and have them install a heat shielded solenoid. I have headers and my starter use to have that problem till they put one of those on.
Ensure all wires are clear and not burned at all.
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
