That's it. The torque converter.
Dyno the motor,look at the torque characteristics and have a custom converter made specificaly for your combination. "Knowing where the engine produces peak torque and the relative "shape" of the curve over the planned range of rpm provides further important input to converter choice and characteristics." Jim McFarland 'Damn right it's a street car'
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
Badbird,
Those are some real nice numbers. I'm running a similar setup in my 68 Convertible. Pretty sure I'll need a roll-bar so I don't know my times yet. 68 FB conv 455 .060 over #64 heads performer intake quadrajet RA-IV cam Hedman headers TH400 trans 3:08 rear Anyone know what the approx ci displacement and approx hp for this motor is? |
462 CI
400 HP? [img]/infopop/emoticons/icon_cool.gif[/img] johnta1 Pontiac Power RULES !!! www.wallaceracing.com
AHAH: here's a heartbreaker:
how about a DYNO that includes the Transmission output shaft? Hmmm, engine, clutch/converter, Trans holding drive, some windage. Inquiring minds wanna know [img]/infopop/emoticons/icon_mad.gif[/img] H.I. Stud "11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
That's why you race on a dragstrip.
Dyno numbers don't win races. Even with a dyno hooked to the tranny output shaft,it still does no good if you don't get the power to the ground. [img]/infopop/emoticons/icon_cool.gif[/img] johnta1 Pontiac Power RULES !!! www.wallaceracing.com
Suppose the real valve is matching the Engine's torque curve to the converter's torque transfer profile vs RPM...very,very big value.
Need the Transmission to best couple to the converter. Think this basket of worms gets worse since the converter's primary value is at low driveshaft RPMs. Geez, with a Trans-friendly dyno, you could theretically optimize your 1/4 mile run on the dyno curve sheet for most area under the curve. Sooo, I would boldy suggest that present engine-only dyno-runs only helps directly with mid-to-top of the track. Subtle, casual or accidental help with 60foot to 660foot. H.I. Stud "11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
Yesh, it's always about power to the pavement.
Since I'm going clutch-auto, getting worried about ever getting an easy 60foot. "11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
Sure it would help quite a bit.Optimizing the torque converter to the engine parameters makes a world of difference in the performance of the car.With the same amount of torque and hp from the engine,there is a large difference in ET with the wrong converter setup.
The problem with most dynos are that they are basically steady state.They hold steady at a certain rpm range,take a reading then go to next. With the tranny hooked up you would basically be bypassing the converter at a steady reading. Thereby negating the torgue multiplication of the converter. [img]/infopop/emoticons/icon_cool.gif[/img] johnta1 Pontiac Power RULES !!! www.wallaceracing.com
Badbird68, Is that a custom hood on your car? If so, could you give out some details about it?
'68 GTO, '68 Firebird, '77 CanAm
![]() "Life is one big smokey burnout after another." -- me |
check out this website, if just for kicks anyway
http://www.land-and-sea.com/rotary-s...shaft-dyno.htm http://www.kingofgtos.com/index.htm
http://www.stockappearingdrags.com http://www.stockappearingdrags.com Come on get off that lawn chair and drive that car like it was meant to be driven. 69' 400 RAIV Judge Conv... 12.86@107 Factory Stock 69' 400 RAIV Trans AM .....12.48@110 Factory Stock 69' 400 RAIV Judge HT..... 13.07@104 Factory Stock 73' 455 SD Trans AM........13's?? not run yet 66' 455 GTO Convert.........12.20@112 non original 63' 421 SD Catalina...........restored fast as h*ll |
562 HP on speed power I told you mid ten;s are eazy!!! I should have saved 10k and built your combo and got a bottle would have run as well as what mine will, and be street driven!!!! [img]/infopop/emoticons/icon_mad.gif[/img]
Bailey, lets switch, Ill take your motor and you take mine. [img]/infopop/emoticons/icon_wink.gif[/img] . I dont think even on the spray that mine will keep up with you. Maybe with a 300 or 400 shot, but that would only be one run until it blew up [img]/infopop/emoticons/icon_eek.gif[/img]. Going to spray it after one more time at the track to do some more tuning. Might try warrior first.
later 68 Firebird 468 #16 D-Ports w RPM intake Street Car 10.47 @ 129.21 150 shot soon
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046s 1.079 4.52 155.15 3000 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! 7.17 @ 188 1/4 mile (2024) Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
The mans car looks and sounds awesome. I tried to swap him for my 65 but he would'nt bite.
Absoulty beatiful car. My Rig's a little old, but that don't mean she's slow.
WWW.PatriotGuard.org Standing for those that stood for us. Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I. One for your soul; the other for your freedom |
Hey Bud what's up? Thanx for the words. His car is super clean too. Great looking car. Sorry didnt hang out, but was with too many other couples that weekend. Maybe ill see ya around.
Going to cecil county next Sat the 26th. Nucar chevy is renting the track. Probably going to spray it so hope the rear holds together. Going for 9's!!!!!!! later 68 Firebird 468 #16 D-Ports w RPM intake Street Car 10.47 @ 129.21 150 shot soon
