Old 10-08-2002, 07:42 PM
Steve C. Steve C. is offline
That's it. The torque converter.
Dyno the motor,look at the torque characteristics and have a custom converter made specificaly for your combination.
"Knowing where the engine produces peak torque and the relative "shape" of the curve over the planned range of rpm provides further important input to converter choice and characteristics."
Jim McFarland
'Damn right it's a street car'
Old information here:
Old 10-09-2002, 05:08 AM
Roy Zink Roy Zink is offline
Badbird,
Those are some real nice numbers. I'm running a similar setup in my 68 Convertible. Pretty sure I'll need a roll-bar so I don't know my times yet.
68 FB conv
455 .060 over
#64 heads
performer intake
quadrajet
RA-IV cam
Hedman headers
TH400 trans
3:08 rear
Anyone know what the approx ci displacement and approx hp for this motor is?
Old 10-09-2002, 07:27 AM
462 CI
400 HP?
[img]/infopop/emoticons/icon_cool.gif[/img]
johnta1
Old 10-09-2002, 10:03 AM
AHAH: here's a heartbreaker:
how about a DYNO that includes the Transmission output shaft?
Hmmm, engine, clutch/converter, Trans holding drive, some windage.
Inquiring minds wanna know [img]/infopop/emoticons/icon_mad.gif[/img]
H.I. Stud
"11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs
12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
Old 10-09-2002, 10:07 AM
That's why you race on a dragstrip.
Dyno numbers don't win races.
Even with a dyno hooked to the tranny output shaft,it still does no good if you don't get the power to the ground.
johnta1
Old 10-09-2002, 10:12 AM
Suppose the real valve is matching the Engine's torque curve to the converter's torque transfer profile vs RPM...very,very big value.
Need the Transmission to best couple to the converter. Think this basket of worms gets worse since the converter's primary value is at low driveshaft RPMs.
Geez, with a Trans-friendly dyno, you could theretically optimize your 1/4 mile run on the dyno curve sheet for most area under the curve.
Sooo, I would boldy suggest that present engine-only dyno-runs only helps directly with mid-to-top of the track. Subtle, casual or accidental help with 60foot to 660foot.
H.I. Stud
Old 10-09-2002, 10:14 AM
Yesh, it's always about power to the pavement.
Since I'm going clutch-auto, getting worried about ever getting an easy 60foot.
Old 10-09-2002, 11:03 AM
Sure it would help quite a bit.Optimizing the torque converter to the engine parameters makes a world of difference in the performance of the car.With the same amount of torque and hp from the engine,there is a large difference in ET with the wrong converter setup.
The problem with most dynos are that they are basically steady state.They hold steady at a certain rpm range,take a reading then go to next.
With the tranny hooked up you would basically be bypassing the converter at a steady reading.
Thereby negating the torgue multiplication of the converter.
johnta1
Old 10-10-2002, 04:06 PM
GTOken's Avatar
GTOken GTOken is offline
Send a message via AIM to GTOken Send a message via MSN to GTOken Send a message via Yahoo to GTOken
Badbird68, Is that a custom hood on your car? If so, could you give out some details about it?
'68 GTO, '68 Firebird, '77 CanAm
"Life is one big smokey burnout after another." -- me
Old 10-10-2002, 04:14 PM
GONZO's Avatar
GONZO GONZO is offline
check out this website, if just for kicks anyway
http://www.land-and-sea.com/rotary-s...shaft-dyno.htm
http://www.kingofgtos.com/index.htm
http://www.stockappearingdrags.com
Come on get off that lawn chair and drive that car like it was meant to be driven.
69' 400 RAIV Judge Conv... 12.86@107 Factory Stock
69' 400 RAIV Trans AM .....12.48@110 Factory Stock
69' 400 RAIV Judge HT..... 13.07@104 Factory Stock
73' 455 SD Trans AM........13's?? not run yet
66' 455 GTO Convert.........12.20@112 non original
63' 421 SD Catalina...........restored fast as h*ll
Old 10-11-2002, 01:58 AM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
562 HP on speed power I told you mid ten;s are eazy!!! I should have saved 10k and built your combo and got a bottle would have run as well as what mine will, and be street driven!!!! [img]/infopop/emoticons/icon_mad.gif[/img]
Old 10-13-2002, 06:16 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Bailey, lets switch, Ill take your motor and you take mine. [img]/infopop/emoticons/icon_wink.gif[/img] . I dont think even on the spray that mine will keep up with you. Maybe with a 300 or 400 shot, but that would only be one run until it blew up [img]/infopop/emoticons/icon_eek.gif[/img]. Going to spray it after one more time at the track to do some more tuning. Might try warrior first.
later
68 Firebird 468
#16 D-Ports w RPM intake
Street Car
10.47 @ 129.21
150 shot soon
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 10-13-2002, 10:25 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
The mans car looks and sounds awesome. I tried to swap him for my 65 but he would'nt bite.
Absoulty beatiful car.
My Rig's a little old, but that don't mean she's slow.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 10-18-2002, 06:50 PM
Hey Bud what's up? Thanx for the words. His car is super clean too. Great looking car. Sorry didnt hang out, but was with too many other couples that weekend. Maybe ill see ya around.
Going to cecil county next Sat the 26th. Nucar chevy is renting the track.
Probably going to spray it so hope the rear holds together. Going for 9's!!!!!!!
later
68 Firebird 468
Street Car
10.47 @ 129.21
150 shot soon
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
