Old 02-02-2003, 06:28 AM
chris spires chris spires is offline
I have a 67 Catalina. When I turn the right turn signal on with the brakes applied and the lights on, the left brake lights go back to their regular brightness.(like I'm not pushing the brakes.)When the lights are off and the brakes applied,and the right signal on, the left side goes out.But, it doesn't do it vice-versa, and there are no other problems other than that.When the signal goes off, the left side brightens back up.What's the dealio??
Don't blame me cause your chevy broke down, you should have bought a PONTIAC!!
Hey are you ready to go, got the top turned down on my GTO. Come on,let's all jump in, gonna take this car for a little spin!!
Old 02-02-2003, 07:54 AM
gtoguy1967 gtoguy1967 is offline
sounds like a bad ground posiably at the socket. i would look for some corosin (sp) near or at that socket. it might just need mved around for a new connection.
Don
some times when you race with squirrel's, you get your nut's cracked!
some times when you race with squirrels you get your nuts cracked!
Old 02-03-2003, 08:26 AM
What does the front turn signals do?
I'd try changing the bulbs first.
johnta1
Old 02-03-2003, 11:55 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
I had the same problem with my 66. My problem was solved by pulling all grounds, scuff and clean connector and surface, applying some dielectric grease and adding a star washer. Make sure you check the ground wires going to the front lights also, all lights are on the same circut.
Good luck.
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph
Old 02-20-2003, 03:38 PM
nickg nickg is offline
this might sound stupid but it's real easy to mix up bulbs, make sure or switch w/a known good bulb.
