Old 06-28-2006, 02:16 PM
Goatboy69 Goatboy69 is offline
Default Rally Gauge Cluster Rebuild
First time poster looking for info and want to share my experiences. Got a few cars, this is my first GTO. Found a nice 69 low option Texas car (built in Arlington, owned in Dallas). Motor seized and was parked in 74 with 56K on odometer. Has a 455 in it now and just received the #'s matching engine from the rebuilder in Tulsa.
In the meantime I was attempting to add a rally cluster to the car and found one on ebay. I took some pix before I tore it apart but now need clarification on how the double thick nuts are used, couldn't tell from my pix. I think they are on the U shaped insulator but not sure. Can anyone confirm or share some pix of a cluster ?
Here are some before pix....I'll post some in progress pix as I go.
Thanks for any help.
ID:	57394   Click image for larger version
ID:	57395   Click image for larger version
ID:	57396   Click image for larger version
ID:	57397   Click image for larger version
Old 06-28-2006, 02:20 PM
Default Additional before pix
I removed the goo that was some sort of foam and soaked the case in Eastwood rust remover then clear coated it.
ID:	57399   Click image for larger version
ID:	57400   Click image for larger version
ID:	57401   Click image for larger version
Old 06-28-2006, 07:46 PM
87LC2's Avatar
87LC2 87LC2 is offline
I like the 140 speedo, good luck.
Old 06-30-2006, 05:05 PM
Default After cleanup
Begin Piecing it together....new Printed Circuit (may try to save the old one-had 3 cracks near the plug)
ID:	57626   Click image for larger version
ID:	57627   Click image for larger version
Old 06-30-2006, 11:06 PM
marauder's Avatar
marauder marauder is offline
Default 140 mph
I have a 140 mph one in mine too, I beleive it's from a '70
Old 07-06-2006, 10:46 AM
You are correct it is a 70 speedo, I am actually going to keep my 69 but was tempted to upgrade.
