Old 01-12-2007, 01:00 PM
robbie9999's Avatar
robbie9999 robbie9999 is offline
Default 2 questions need help on 66 dash
Guys need your help
1. take a look at the pic attached where do you get a dash insert in this nice dark colour, or is this some type of after market thing ... as well notice how clean his bezels look, is that from the chrome plate inside the scoops ?
2. the bulbs for the dash how many are there and what type do I need to get ? and from where ?
please assist
1966 GTO TRI-POWER
Old 01-12-2007, 01:02 PM
robbie9999's Avatar
Default sorry here is the pic
the pic of the wood panel I am looking for
Name:	WOOD PANELING NCE AND DARK.jpg
1966 GTO TRI-POWER
Old 01-12-2007, 05:04 PM
fred kobbe fred kobbe is offline
Default 66 GTO DASH
HI ROBBIE
JUST FINISHED MY 66 FRAME OFF RESTO ,CHECK IT OUT AT FREDSGTO.COM
OUR HOST HAS THE VENEER WOOD GRAIN AS WELL AS THE ALUMINUM BACKING PLATE ,IF NEEDED,MAKE SURE YOU GET THE ADHESIVE TYPE VENEER AND NOT THE ONE WHERE YOU APPLY ADHESIVE THEN TRY TO SET THE VENEER ON IT. THE VENEER IS LITE ,NATURAL WOOD, SO YOU CAN STAIN IT ANY COLOR YOU WANT.FOR SURFACE PROTECTION I PUT 2 COATS OF CLEAR POLY U ON. IT CAME OUT BETTER THAN SHOWROOM.
AS FOR THE DASH INSERT,I HAD MINE REDONE WHERE THEY MAKE ANY REPAIRS NEEDED AND RECHROME THE BEZELS AND PAINT THE INSERT.HAD MINE DONE AT C.V VACUUM PLATERS IN VANCOUVER B.C. I WOULD NOT RECOMMEND THEM,NOT BECAUSE OF THE WORK IT WAS EXCELLANT, BUT BECAUSE IT'S OUT OF THE COUNTRY. THEY LOST MY INSERT FOR 3 WEEKS AND THEIR COMPLETION PROMISE IS NO GOOD.I SINCE FOUND OUT THAT THERE ARE PLACES IN THE STATES THAT DO EXCELLANT WORK.
I WILL CHECK OUT MY DASH LITE DIAGRAM AND GET BACK TO YOU ON THE LITES.ONE OF THE OTHER GUYS MAY KNOW ALSO.
GOOD LUCK
FRED
STILL SPENDIN MONEY HAVIN FUN GOT ER DONE
Old 01-12-2007, 06:51 PM
lcoz31 lcoz31 is offline
Robbie, I used c.v. vaccum platers also. The work was good and turn around time was ok, then again you have to plan ahead and allow for delays. Someone from this site recommended to stain the wood veneer with tung oil, from the hardware store, which I did. Turned out nice, lighter than your picture. The more coats, the darker. Also, the glare from the bezels is probably a new plastic lens. Larry.
Old 01-12-2007, 08:03 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
My dash I did a little while ago was lighter too
Name:	100_0169newdash (Small).jpg
Old 01-12-2007, 11:14 PM
BOB VIDAN BOB VIDAN is offline
robbie9999, on the picture you posted, the insides of the gauge pods are not painted as they should be, that's why they look so bright.
Old 01-12-2007, 11:35 PM
robbie9999's Avatar
Default hhmmm
the inside is suppose to be black ? correct
cause I think this one is all chrome inside or a bright silver
do you know how many bulbs are in the dash and what kind I want to replace them all ...
Sincerely - thanks guys for the info really helping out
1966 GTO TRI-POWER
Old 01-13-2007, 12:35 AM
VintageIgnition VintageIgnition is offline
Send a message via AIM to VintageIgnition
Yes the inside f the gauge tunnels on a 66 GTO are supposed to be black. Steel blue on a 67.
Old 01-13-2007, 01:06 AM
lkt1954's Avatar
lkt1954 lkt1954 is offline
Default Dash Lights
robbie9999:
Here is a picture of a 66 wiring diagram, hope it helps. If I can find my resto-guide I will get you the types of bulbs.
Larry
Get in-Sit Down- Shut Up - Hold On
Old 01-14-2007, 11:03 AM
KVman389 KVman389 is offline
lamp discription bulb# std./opt. qty.
air cond. control 1445 opt 2
ammeter 1895 std 1
ash tray illum 1445 opt 1
auto trans console 1445 opt 1
auto trans column 1445 opt 1
cigar ltr illumn 1445 opt 1
clock 1895 opt 2
console comp. 1895 opt 1
console courtesy 89 opt 1
instr panel courtesy 89 opt 1
turn sig. ind. 1895 std 1
dome lamp 211 std 1
headlamp beam ind 1895 std 1
heater controls 1895 std 1
instr panel comp. 1891 opt 1
oil pressure 1895 std 1
park brake warning 1895 opt 1
radio dial 1895 opt 1
speedo. illumn. 1895 std 4
tach. 194 opt 2
temp. guage 1895 std 1
These are original #'s. I have been able to find replacements, at my local O'rielys, Auto Zone, and auto electric shops. Hope some of this helps.
When I turn it on, wind it up, blow it out GTO
Old 01-14-2007, 01:25 PM
robbie9999's Avatar
Default hmm
THANK YOU THANK YOU THANK YOU !!!!
1966 GTO TRI-POWER
