Old 02-06-2007, 11:47 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
The classes we run prevent us from being able to use a 4-link. A 4 link does have several advantages over ladder bars, you can compensate for a bad or really good track as well as hooking with out having to carry the front end as much. That said one of our cars 60s in the 1.17 range with the back tires on a 29.5 10.5 slick with ladder bars. Wheelie bar adjustments and wheel speed become very critical on this car. FWIW
Old 02-07-2007, 12:44 PM
Goatman Goatman is offline
On Vacation
Originally Posted by Polar-Pontiac
1.35 60ft Ladder bar car all steel motor built by potent pontiac 10 inch tire
Had a 1.37 in my stock suspended GTO.............
In my opinion, unless you're looking to get into the 9's or faster, leave the stock suspension in it. If not, go with a 4 link.
Old 02-07-2007, 02:13 PM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
I heard about that from a friend that some classes don't allow them.
I never want wheelie bars, so maybe a 4link would be better since I can control wheelies with a 4 link. I know that John Langer has a ladder bar car and his doesn't wheelie much. I'll never make power like that. Is there a way to fine tune a ladder bar car so you don't pull the front up as much?
Old 02-07-2007, 02:35 PM
On Vacation
Yep.
But you have to be able to move weight around the car and adjust the front suspension.
Old 02-07-2007, 03:46 PM
ho428's Avatar
ho428 ho428 is offline
Before back halving it have you looked at the Slider Link bars? Once you hack the back, and tub it, you'll probably have to narrow the rear seat.
If anything you could go with a mini-tub, deeper offset wheels, slider links and keep the back half as is.
Just a thought.
I've had Slappers, ladders and 4 links with wishbone on various cars. And now slider links on my 68 Bird. Haven't tested the sliders yet but they seem to offer adjustability and preload without sacrificing ride quality.
4 link was the best on the strip. Ladders worked well on the street and strip but the ride was harsh.
Old 02-07-2007, 04:23 PM
MrPushrod's Avatar
Just a thought.
i just sold my caltracs.
Old 02-07-2007, 04:41 PM
goquick's Avatar
goquick goquick is offline
I'lll see if my buddy will get a picture of his bent slider links. His camaro makes 650 hp in it's current low compression state with the 615.
Old 02-07-2007, 04:59 PM
MrPushrod's Avatar
I've seen bent ones. Haven't seen any bent caltracs though. I miss the caltracs I had. I'm leaning towards the 4link for the adjustability, but I like ladder bars because you can set them and leave them. I don't wanna spend all day tuning a 4 link. If the backseat thing won't work then I will do the 4link. I might be selling my seats, 2 buckets and the rear seat. Does anyone need brand new black seats?
Old 02-07-2007, 05:18 PM
BILTIT's Avatar
BILTIT BILTIT is offline
What kind of buckets?
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 02-07-2007, 05:48 PM
MrPushrod's Avatar
The originals out of my car. New black vinyl. They're beautiful.
Old 02-07-2007, 07:37 PM
BILTIT's Avatar
Do you know if the rear seat fits the ventura's? Is it the same material? I assume the fronts fold ahead for rear seat access. Pretty comfy? Might be what i am looking for.
Derek B.
Old 02-07-2007, 08:04 PM
MrPushrod's Avatar
Yep, same material. The vinyl isn't the correct factory vinyl.
The seats were done by a local upholstry guy
that does most of the hotrods in my town. He's been doing it for
30+ years. I did my homework on all the shops in town and he was
the best. yes the fronts fold and move foward. Comfy, yes, all new foam.
I don't know if the rear will fit in your car. Good question.
Old 02-07-2007, 08:53 PM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
Default Apples to Apples......Not.
Yes you did....But you also had a million motor to do it with. I did this with a all steel motor.No big dollar Wilson ported intake. 1970 GTO Judge clone.
461 400 block.
IA prepped 300cfm E-heads
.660-.680 solid roller.
Wilson ported intake. Modded for EFI by Steve Grebeck.
Eagle stroker kit.
CP pistons.
TH400
ATI 4400 stall converter.
12 bolt with 4.10's and Detroit locker.
29.5x10.5W Et Drag's dollar motor
Old 02-08-2007, 11:22 AM
On Vacation
LOL. That's a million dollar motor?
You must not know much about motors.........
Old 02-08-2007, 01:07 PM
greggutknecht greggutknecht is offline
My old 71 ventura went 9.11 with a 1.33 60ft all steel with a ladder bar and 29.5-10.5w.With my new motor went 8.68 1.33 60ft on 29.5-10.5 non w.There is also a nova in my class that has gone 8.20s with cal tracs and radials.
Old 02-08-2007, 01:33 PM
MrPushrod's Avatar
Is the nova Artis Houston's car?
Old 02-08-2007, 01:42 PM
not sure of the owners name but i think he is from the chicago area.
  #38
Old 02-08-2007, 02:15 PM
MrPushrod's Avatar
Old 02-08-2007, 02:33 PM
Not the same car but it looks pretty sweet.
  #40
Old 02-08-2007, 02:37 PM
MrPushrod's Avatar
That nova just went 7.80's on a 275/60 tire with caltracs.
