I think Steve meant 215-220cc for the ported KRE heads. Definitely to big for a tractor motor
Thanks Skip, I corrected it. big differance and big impact on results.
I got those numbers from a discussion about a set of KRE D-ports that were about 323 cfm at .600 lift. Jeff confirmed it. In contrast Bob Davis KRE ported 310 cfm @ .600 head Edelbrock heads have a 236cc runner (SCE 128105 gasket/ 2.3 ports ) Big inches + big roller + small runner volume heads Last edited by Steve C.; 03-23-2007 at 11:46 PM. |
Don't know where my Desk Top sheets are at the moment but it sems it showed a peak HP(7??) @ 7,400/7,600 RPM. Jack has told me his predictions are about 7,000-7,300 for shift points.. It's going to be a HO tractor motor !! Think I just graduated from "streetable" motors....
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Yes sir, a very cool tractor motor
Really looking forward for your results to be posted. I think its really great that we share our combinations and results with the community, good luck.
Sounds like your going to have even more fun this year 60man.
Hope to see ya at Norwalk.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
"I hate to part with 8 lugs but I also have a Scarebird front disc conversion setting on the shelf. It's not the 1/4 mile tracks that get me...it's those short little 1/8 mile tracks with even shorter shut downs... Have had to change shorts all ready a few times...."
Troy, I've had the same troubles a few times on short tracks with my little old "street" car. I'm glad to see that you are looking at the brake "issue", I thought that you might have been running the old front drums. I had them on several big cars I used to race, they heat up and go out of shape quickly (causing me to have to change my shorts a few times as well), disks are far superior in every way! Do you have a 12 bolt or Ford 9" in the works for the rear?......Cliff
I MAY have to go with 4.30's for 505 combo ?? I plan to stay with the 59-64 9.3" rears with spools. I have a supply of different ratios (4) with Strange spools and Moser axles.. Tackling the two piece drive shaft is next project... Can't see "down sizing"..... CYA at Norwalk...
I'm betting the cam choice not the head cc and flow is making the "proposed" rpm peak that high. I'll still bet the head flow has it lower than the computer estimate for that CI motor.I'll bet 6500 max.
Should make that big tuna boat move on out! |
To much assuming ....I'll wait on the REAL dyno results... 505 may come sooner than I thought...I screwed up at T&T today...bounced off a 7,300 chip and I may have hurt my trusty 462... Only 5-10PSI oil press. at idle...sounds like (hope) I lost ANOTHER oil pump !! It's yanking time ...again ...505 will be in the hole ASAP.. Time to move this "Tuna boat".... Just for giggles...I saw a set a SBC heads in TN with ports that looked 1/2 the size of mine....damned things flowed 440 CFM !!! The bowls looked like pint milk containers..
Hey Mate,
sorry to hear about the 462...But I know that you can't wait for the 505 to go into the bay so you can have some fun. Did you get my email from [email protected]? Should be going for a spin in mine tonight hopefully if the weather stays alright. it will be the first outing with the 474back in. Gas |
By Cliff:
WWW.PatriotGuard.org Standing for those that stood for us. Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I. One for your soul; the other for your freedom |
Hey Homo......is that your new ride in Avatar ?? Harley or a Victory ?? Tuna Boat huh ?? Then it smells OK ??
60's man, are you running stock caps on that rear end? I busted two sets, Mark Williams makes billet caps for that set up. Since I upgraded, no problems.
I have billet caps on two set ups...need one more set for my 4.10's. Going to try 4.30's with the billet caps this season with the 505, if tires can hold it.. I feel a little uneasy with the stock caps.. What power level are you running and is it a stick..??
Did you take a ride with 474 ??
My 1965 GTO has a 455+.030 with D-port heads, a Jerico 4spd with 4.56 gears on a nine inch tire and weighs 3600lbs. The car has run 10.87@124MPH. What weight will you be running with your 60?
60man Inland Empire makes a beefy two piece driveshaft for the X frame 58-64 Chevies. Beefy support also.
#38
#39
Thanks ...I will check with them...never hurts.. So far I have not had any problems..only blew one u-joint..the front one ??
#40
Sounds good 60 man.Hope you didn't hurt the motor. Bob
