Old 04-16-2007, 06:26 PM
tom s tom s is offline
Dave,tell him about the "dead spot"these intakes sometimes show!LOL,Tom
Old 04-17-2007, 09:50 AM
White Warrior White Warrior is offline
I noticed on my race car,driving around the pits, that around 3000 rpm,especially after the engine was hot, that my engine sounded like I had a broken rod. It's fine above and below that rpm range but I have no idea how it will respond on the street.
This may be why the manifold was originally designed to use a small one barrel carb mounted between the AFB's.
If I ever get the oportunity to talk to Malcolm McKeller again,I will ask him. He designed that manifold.
Old 04-17-2007, 11:46 AM
Cool
I'm going to give progressive linkage a try at first, running off the primaries on the rear carb for putting around town.
I have a TH400 with a 3500 flash-stall 10" Continental converter and 3.89 gears with 28" tires, should be running right around 2500 RPMs around town doing 50 MPH.
We'll just have to wait and see.
Looks like there's room for a 2-barrel idling carb in between the two 4-barrels.
Old 04-17-2007, 03:26 PM
Sure looks better than our P65! I'm jealous.
Old 04-17-2007, 03:42 PM
GRX's Avatar
GRX GRX is offline
Good stuff as always b-man
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
Old 04-17-2007, 04:35 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
this was really designed to have a 1V carb installed tween the 2 main carbs?>??????????
wow, novel and neato.
is this thing on?
Old 04-17-2007, 04:44 PM
Would be a great intake for EFI conversion too!
Old 04-17-2007, 05:18 PM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Thumbs up
Very cool looking intake.Should turn some heads when your out cruising.
Old 04-17-2007, 05:39 PM
60man's Avatar
60man 60man is offline
I hpoe you like it.I should have made more of them before I sold the patterns to Randy Williams
Dave....who has the patterns now since Randy passed on ??
Still the estate...?? Wonder who will wind wth those..........
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 04-17-2007, 06:11 PM
Talking
If you check out some of the pics of factory bathtub intakes in Pete McCarthy's book you'll see 2 holes bored for a 2-barrel carb as well as 3 tapped holes to attach it. There is a small block-off plate covering the spot where the 'extra' carb should go in one pic. On later versions of this intake the provisions to mount the center idling carb were eliminated.
I have a few early Ford Holley 94 carbs with the 3-bolt flange up in my attic, guess I'll have to climb up there and get one down to see if it fits.
Waaay back in the day (probably high school) I can remember someone telling me about a Pontiac intake that had two 4-barrels with a 2-barrel in the middle.
I told them they were nuts.
Old 04-17-2007, 10:36 PM
Talking
Looks like there's just enough room for a 2-barrel.
I couldn't fit it in there because of the size of the linkage arms on both sides of the Holley, the engineers must have had to use a very close-coupled throttle arm on one side only in order to squeeze it in.
The 2-barrel Holley 94 is a full 2 inches taller than the Carter AFB 4-barrels, 5-3/4" vs 3-3/4".
Old 04-17-2007, 11:22 PM
ALL factory intakes had the holes castin with a blockoff plate.The factory intake was way diff inside with a plate seperating the top and bottem.My engine lost 100 rear wheel HP between 4000-5000 with my setup with one of Daves intake.The repops are better than the factorys thanks to Daves R&D.I think the Randy intake with the V plenum is the best HP intake.You will have no problem with the idle on the intake and progressive works the best for the street and solid at the track.NEVER ran one with a auto!Tom
Old 04-17-2007, 11:48 PM
Cool
I'm on a roll this week, can't be stopped even after working 10-1/2 hour days all week.
I sat the intake on top of my engine today, it won't sit all the way down in front unless I replace the '69 valley pan with a '67 or earlier one. After I replace the valley pan it will sit down another 3/8" in front.
So far so good.......
Now for the aluminum foil ball hood clearance test.
View from inside the passenger fender, there are no inner fenders on the car.
Open up the hood and lay the straightedge on top of the crushed foil, then take some measurements. I put a dial caliper on the foil after removing it, 2.450" at the rear and 1.800" up front, add .375" to the front measurement since the intake sits too high by that much giving me 2.175".
Glad it all fits under the hood.
I'll build an air box out of sheetmetal to enclose the tops of the carbs and hook up some fresh air ducting to it, clearance will be tight but it's going to be just enough.
Stock throttle cable should work fine.
Couple more shots.....
The lucky recipient, er old wreck.
Old 04-18-2007, 09:20 AM
Default Bathtub intake.
I would not bother trying to make the original water passages work with the 65 and later heads,not a good match. Just cut the original water crossover off and use one cut off a late aluminum manifold. The ones Randy did i believe may have incorperated the later crossover but those are scarcer than the ones I made.
Attached are pix of my V-plenumed manifold that made about 850 hp with2 800cfm Edelbrocks on a 446" NA engine. No other manifold or carb combo made more power and I tried many other combinations including Demons on a Wentzler Gutsram
ID:	88888   Click image for larger version
Old 04-18-2007, 09:25 AM
Way too cool B Man! A buddy has an orignal 64 Tripower GTO project that same color!
My college freshman biology TA in 1972-3 was a Pontiac guy. I saw him when I had the Impala SS in the staging lanes at a Dallas race, was good for a few extra points on my next quiz. He had 2 64 GTOs and multiple old intakes, a bathtub, a M/T crossram. He had put the bathtub once he said. Used a wagon's 2/56 or so rear end to help rpm with the comute. Phil Bauman was his name for any of you Dallas guys that may remember him. Always liked that bathtub intake.
Bet they would sell if someone had the patterns!
Old 04-19-2007, 07:03 AM
Geoff Geoff is offline
850hp! And we keep hearing how bad Edelbrock carbs are!
Old 04-19-2007, 03:55 PM
When you launch a Pontiac drag race car off the line at 6000 RPMs the weak points of the E-carbs (the secondary flaps calibrated/weighted for a 350 Chevy) won't become evident.
Most of the guys running them on modified street Pontiacs already know how bad they are at bogging in transition to the secondaries.
That's the main reason I sought out old Pontiac AFBs rather than use new E-carbs, so they will run well on the street.
  #38
Old 04-19-2007, 05:23 PM
It's too bad Edelbrock doesn't offer air valves with different weight counterweight air valves to solve that problem. The 625 cfm AFB on my 299" 63 avanti transitions just fine and the carb is bone stock.
  #39
Old 04-19-2007, 06:29 PM
tempest455's Avatar
tempest455 tempest455 is offline
Also if running an 8" 5,000 stall converter the E carbs are not a problem!
Tempest455
  #40
Old 04-20-2007, 07:39 AM
The 800 E card was a completely new carb from the ground up. The original AFB only came as big as 750 cfm & had 1 11/16" throttle bores. The E carb has 1 3/4" throttle bores with all new venturi clusters. It also runs a much lower float level, 7/16" compared to 5/16" for the Carter Comp Series AFBs. I was never able to make my carb bog, even punishing it with WOT stomps at 15mph, in high gear with a manual valve body, & 3.08 axle.
