Old 04-24-2007, 12:52 AM
RiceCooker RiceCooker is offline
Send a message via AIM to RiceCooker
Default head gasket choices
what type of head gaskets do you guys recommend.
I know, I'm full of questions today.
Old 04-24-2007, 08:27 AM
Mr. P-Body Mr. P-Body is offline
What heads? Compression ratio? Adders?
Jim
Old 04-24-2007, 09:50 AM
092 10.5:1 will have a 125 shot of some juice.
Old 04-24-2007, 03:50 PM
Tim Corcoran's Avatar
Felpro 1016 should work fine but Cometics are the best. RSB Motorsports have the best price for Cometics if you decide to go that route.
Tim C
Tim Corcoran
Old 04-24-2007, 08:27 PM
Tim C
what is the difference between the felpro and cosmetics?
Old 04-24-2007, 09:58 PM
myckee's Avatar
myckee myckee is offline
The felpros gaskets and are usually made out of specialised fibrous materials and usually used by the automotive industry. Cosmetics refer to coloured substances, typically worn by women, some times in rather high amounts, on their faces.
Old 04-24-2007, 09:59 PM
BVR421's Avatar
BVR421 BVR421 is offline
about a hundred and twenty five dollars
Old 04-24-2007, 10:01 PM
myckee's Avatar
lol Sorry I couldn't resist. Cometic gaskets usually have a steel plate sandwiched between two thin gaskets and are thought to be pretty much blowproof. They are about four times the cost of the felpros.
Old 04-24-2007, 10:09 PM
rkm1003's Avatar
rkm1003 rkm1003 is offline
The guy who is building my engine swears by these....http://www.scegaskets.com/ ....FWIW....
'69 Pontiac 400 YA, .060 over, stock crank, 10.2:1 comp, CAT H-beam rods, HS 1.65 rockers, Crane cam 248/252 660 lift, Edelbrock 72cc heads ported 300 cfm, Performer RPM Intake, Ruggles 800 cfm Q-jet, Summit 140 gph electric fuel pump, 12 bolt 4.10 posi, 200-4R, Transgo HD shift kit, 2800 stall, aluminum radiator, 2" MadDog Headers, DMH 3" cutouts.
12.51 et @ 111 mph
Old 04-24-2007, 10:20 PM
that was rather humorous.
well, I won't be spraying it alot...think i might just use the fel-pros
Old 04-24-2007, 11:10 PM
Philcol Philcol is offline
Smile
Just a little FYI. I have had my heads off three times and reused the original Felpros with no issues. Also have 12 1/4 to 1 CR. There are others on this forum who have done the same.
Phil
"dreamed I was wide awake........woke up and I was sound asleep"
Old 04-24-2007, 11:45 PM
66PROGTO 66PROGTO is offline
I too have had good luck with the Felpros, however I just installed cometics on my new IA II. Jim Butler swears by them. He told me to torque them 100- 105 lbs. then retorque. They are also supposed to be reusable but that's not usually my style. they consist of three layers of ??? metal with rivots in all four corners.
Old 04-25-2007, 08:59 AM
While MLS (multi-layered steel, what Cometec sells) gaskets are the "rage", they're not necessary for such a build. The Felpro is the standard by which all others are measured. Also, the MLS gaskets have very specific surface finish requirements, and are much less forgiving than the fibre gaskets. If your heads and block have been resurfaced by a modern machine (wth a CBN or similar cutter), the finish will be fine. If they were done on an older style "broach", the RA (roughness average, formerly refered to as "RMS") will be too high for the MLS gaskets. We (CVMS) recently installed a modern surfacer for this very reason. ALL the modern engines (aluminum heads AND blocks, for the most part) use MLS technology. We couldn't get a factory "approved" finish on a Neon head with the old one. We can use them to "brush your teeth" now... (:-
FWIW
Jim
Old 04-25-2007, 02:19 PM
Tim john Tim john is offline
The 1970 455 was considered the best designed head gasket and Butler Performance I belive owns the original Fitzgerald dies or knows who does and he then has an endless supply so you may want to contact the Butler family (Butler Performance) and give them a try, this is what I use and I purchased mine through the Butlers, absolutely wonderful people to deal with.
Tim john---
