74 Ventura 462/#13 heads/3350# 10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured |
i was thinking of using auto trans assembly lube
Holy crap...this is an old thread. Rashionality? Craig Berkheimer? WD40 works well as an assembly lube, it's all I've ever used to keep the threads from galling.
i found it while looking for AN fitting info and figured i would bump up the oldest AN fitting thread for my questions
Wives Tale about a -8 hose being .500 id
Aeroquip hoses are not as ASSUMED for inside diameter and area. A -8 hose is not a .500" inside diameter with a .2 sq in of area. It is about 25% LESS. Actual--------Assumed---------Actual-------Assumed--------Percentage Diameter-----Diameter---------Area-----------Area------------Of Error 0.22------------0.25-------------0.04-----------0.05-------------0.23 0.34------------0.38-------------0.09-----------0.11-------------0.18 0.44------------0.5--------------0.15-----------0.2---------------0.23 0.56------------0.63-------------0.25-----------0.31--------------0.2 0.69------------0.75-------------0.37-----------0.44--------------0.15 0.88-------------1.0-------------0.61-----------0.79--------------0.23 If you want at least a .2 sq inches of area you need to step up to -10 hose. .8 hose has .15 sq in of area. Roughly a 25% smaller area than assumed Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 07-29-2007 at 07:29 PM. |
one more thing..
how can i hook this Summit Racing part number MOR-65385, to AN fittings, http://store.summitracing.com/partde...0&autoview=sku thanks |
1) Get an aluminum a/n fitting that matches the small tube id of the part from Summit.
2) Cut off the threads on the male end of the fitting 3) Clamp the fitting in a vice and open up the id to the same od as the part from Summit. 4) Cut off the barb on the summit part and press it into the male fitting and then tig the two parts together. 5) You will now have a properly installed male fitting that you can hook to a female EFI return line that will be safe and handle high pressure. Tom V.
good idea, thanks Tom!!
what about the pipe coming off the gas tank sender on a 65, is that aluminum also? if not how can i make that connection? or maybe i should just drop the tank, plug the old gas sender and weld in some of those fuel cell fittings with a new pickup tube/-8AN lines..im not sure what to do now, lol its for the tripower carbs not the nitrous, my goal is to get rid of all those rubber hoses and install a return line on the tripower. thanks |
Years ago I took the tank sender out of my 64 GTO, used a torch to melt the solder on the main fuel line, used a drift punch to flare/open up the opening to 1/2" tube, and then I resoldered the tank sender.
I also put the fuel level sender on the 1/2" tube in the right spot so it worked again. It worked well enough but if I ever put a high performance tank under my GTO it will have a sump and -12 fittings and I will leave the stock fuel level sender where it is and plug the hose nipple at that location. A proper sump works SO MUCH BETTER vs a modified pick-up. JMO Tom V.
thanks Tom,,,, im going to give that soldering idea a try.
Also, get the vice jaws that hold the hose fittings. It makes it 100000 times easier to assemble the hose ends.
