Old 08-03-2007, 10:52 PM
Goathead's Avatar
Goathead Goathead is offline
Send a message via AIM to Goathead
Default Oil filter relocation kit question...
When you use an oil filter relocation kit, where is the best place to put your fitting for the oil pressure guage?
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC]
http://www.youtube.com/watch?v=iJrDl3nRNCM
http://www.youtube.com/watch?v=Fvywdocl4GA
http://ultimategto.com/icongraf/65headtitle.jpg
Old 08-03-2007, 10:53 PM
On the top of the block next to the distributor, LOL!
Old 08-03-2007, 11:15 PM
Goathead's Avatar
Is the block already tapped there Tom, I've never noticed...
Old 08-04-2007, 12:47 AM
WDCreech's Avatar
WDCreech WDCreech is offline
It takes a 5/16" square socket to get the plug out. I chased a Snap-On truck down to get one, once.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 08-04-2007, 01:03 AM
WARPed's Avatar
WARPed WARPed is offline
Or grind down a 3/8 extension
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 08-04-2007, 04:00 AM
lust4speed's Avatar
Never had much luck using any straight 5/16" piece on the plug. Those suckers are firmly stuck after 40 or so years. Best I have found is the Sears square (four) sided easyout that has the bottom portion cut off so the start of the tool is just over 5/16" and by design goes bigger. The tool should have to be tapped firmly into the plug. A twelve point 1/2" drive socket on the end of the easyout with a fairly large handle for leverage usually works. Many are a coin toss on what is going to give first - the easyout, the socket or the plug. Plug has always lost, but sometimes it's worrysome.
If the engine is torn down to bare block, I simply drill through the plugs and tap in a normal 4-sided easyout and proceed as above.
Mick Batson
Old 08-04-2007, 07:50 AM
tempest455's Avatar
tempest455 tempest455 is offline
You will get a different pressure reading at the dist than at the filter housing.
Tempest455
Old 08-04-2007, 11:49 AM
Brian Baker's Avatar
I ground down an old extension to get mine out. Didn't want to come out at first, but a little heat from a propane torch made quick work of that.
Old 08-04-2007, 09:38 PM
Goathead's Avatar
Well, I guess it was my luck day, for a change. Not only did the plug come out pretty easy, but I actually had all of the fittings necessary to get it back together without leaving the garage....now that's something rare......
Thanks everyone...except Tom...
Old 08-04-2007, 10:14 PM
I would expect nothing less from you Danny! (:>))))))
Old 08-04-2007, 10:56 PM
Goathead's Avatar
Has anyone had any bad experiences after installing one?
Old 08-05-2007, 12:04 PM
Only if they used the wrong sized lines, the wrong filters, the wrong fittings, the wrong oil filter adaptors, etc.
Common sense says you do your homework before hand which you are obviously doing because you asked the question.
Old 08-05-2007, 01:04 PM
David Holmberg's Avatar
I twisted my ankle walking back into the house after doing mine...
Old 08-05-2007, 05:43 PM
Goathead's Avatar
Yeah, but you twist your ankle finding the keys...
Let me know if I need to change anyting about the hook up. Going to a longer filter when this one is done. In's to outs and # 10 line. With the Dougs headers and straight fittings, this one was a breeze....
ID:	100280   Click image for larger version
Name:	Filter 2 resize.JPG
ID:	100281   Click image for larger version
Name:	Filter 3 resize.JPG
ID:	100282   Click image for larger version
Name:	Filter 4 resize.JPG
ID:	100283   Click image for larger version
Name:	Filter 5 resize.JPG
Old 08-05-2007, 08:37 PM
What Oil Filter adaptor did you use there Danny?
Old 08-06-2007, 09:33 AM
Goathead's Avatar
Came from AllPontiac, but I believe it's amde by perma-cool Tom.
