Old 09-07-2007, 11:43 AM
jackman jackman is offline
Default Engine serial number on 89 Trans Am GTA
Does anyone know where on the engine I can find the factory numbers. I recently aquired a 1989 Trans Am GTA with a 350ci and am trying to determine if the engine is original. I was told the last four numbers should match the last four of the VIN.
Old 09-08-2007, 12:31 AM
WDCreech's Avatar
WDCreech WDCreech is offline
This belongs in Pontiacs with non Pontiac engines. And who cares?
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 09-08-2007, 01:36 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Its on a machined pad at the head/block seam on the passenger side behind the A/C compressor.
Old 09-09-2007, 08:33 AM
Thanks, Do you know anything else about engine numbers? All I see there is either a #7 or a poorly stamped Z, I think it's the Z. Or do you know where I can look this code up?
