Old 09-12-2007, 01:10 PM
Ken -Ace- Brewer's Avatar
Ken -Ace- Brewer Ken -Ace- Brewer is offline
Send a message via Yahoo to Ken -Ace- Brewer
Default NEW Pontiac Crosswind manifold!!
Available NOW!!
Be Cool,
Ace
Name:	Dual Plane[1].JPG
Am I glad I got out of the business I was in? HELL YEAH!!!
Old 09-12-2007, 05:00 PM
Larry Navarro's Avatar
is the polished manifold available as well?
Old 09-12-2007, 06:45 PM
Yes!
Be Cool,
Ace
Old 09-12-2007, 07:15 PM
rcread's Avatar
rcread rcread is offline
Oooh, and it fits under the hood.
Great. Now what am I supposed to do with the Performer I have? Artwork for the office?
Old 09-12-2007, 09:26 PM
chuckies76ta's Avatar
Ken: Do it actual fit under the shaker on a Trans am?
Thanks Charles
Old 09-12-2007, 09:50 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Looks to me to be as tall as a Performer RPM so I am pretty sure it won't fit under a shaker without something like Larry Navarros WFO Breather...
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads
Faster on nitrous…
Old 09-12-2007, 09:51 PM
69Goat1's Avatar
BTW - Price? - I may be in the market because I like how it has no heat crossover.
Faster on nitrous…
Old 09-12-2007, 10:07 PM
cdoggy81's Avatar
cdoggy81 cdoggy81 is offline
$189.95 for Satin and $249.95 for a polished.
If the RPM won't fit, neither will this one. Basically it's a cleaned up version of the RPM.
If you want one to fit, get the tomahawk.
73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014
Last offical pic of the car can been seen here:
http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf
People have seen it posted FS on Craigs List back in late 2013 early 2014....
IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!!
Old 09-13-2007, 07:35 AM
If the Crosswind is patterned after the RPM, the WFO would be the option if you wish to keep the shaker in the original location.
Old 09-13-2007, 09:08 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Ken, we have effectively modified our Shaker assembly to run an RPM intake with the stock components, thanks to Rocky Rotella.
If you ever want one of those intakes tested, I need a "second" or one we can remove the water crossover from for the test?
Currently we are running a stock, untouched RPM intake, and the weather is improving dramatically here. Still time to get some good back to back runs with the intakes. Let me know, PM or [email protected] ...thanks.....Cliff
Old 09-13-2007, 06:05 PM
cdoggy81's Avatar
"we have effectively modified our Shaker assembly to run an RPM intake with the stock components"
Any pics of it Cliff or Rocky?
Old 09-13-2007, 06:10 PM
73ta's Avatar
73ta 73ta is offline
Cliff or Rocky, tell us more about that!
Old 09-13-2007, 07:40 PM
Yeah Cliff.....go ahead and tell them.....
Old 09-14-2007, 11:01 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
To keep you all from sitting in suspense, there really wasn't anything to it.
Cliff had a '74 GTO Shaker assembly on his Ventura, and the GTO scoop has a large, sheet metal spacer rivited to its base, which properly locates the scoop. (The Ventura/GTO hood line is higher in relation to the carb).
I supplied Cliff with a '73-76 Trans Am Shaker, which has no spacer, and he mounted that directly onto his existing Pontiac air cleaner. The extra space gave him the chance to run a taller manifold, or a stock manifold with a tall spacer.
Unfortunately, that's all there is to it!
Old 09-14-2007, 11:37 AM
BAD2000TA BAD2000TA is offline
Pictures. please??!?!?!
2001 Pontiac Trans Am WS6, 6-Speed, LS6 block, TEA LS6 heads, 4" SCAT forged crank, SCAT H-Beam rods, 226/234 cam, McLeod RST clutch, SLP Lid, SLP Power Flo Catback
1980 Pontiac Trans Am Y-84 Bandit WS6, 455 (.030 over), #96 Heads, Hedman headers, Wolverine 234/244 cam, Performer intake, Holley Sniper
"Need a car to run blocker. Speedy car. Speedier than that....."
Old 09-14-2007, 11:53 AM
Gotta talk to Cliff about that one...
Old 09-14-2007, 12:04 PM
....as opposed to a trans am, where the hood line is lower in relation to the carb.
Duplicating what was done to Cliffs shaker will not work for those that already have a trans am.
Old 09-14-2007, 01:51 PM
Cliff R's Avatar
There's nothing special to take a pic of? Rocky had a 1" shorter Shaker top, we install an RPM intake that was 1" taller, used the stock air cleaner base, added the shorter top, everything fits perfectly. We just had to modify the throttle bracket and the hose coming up from the valve cover.....Cliff
Old 09-19-2007, 03:30 PM
Formula jg Formula jg is offline
...guess us Formula and Firebird guys are SOL for it to fit under the hood line?
Old 09-19-2007, 07:40 PM
cdoggy81's Avatar
If you want a new one to fit, get the tomahawk.
You can also mill the Torker II down (talk to Butler about that one).
