Old 11-06-2007, 10:56 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
Default SD455 Intake Manifold Gaskets
Anyone know of a source for correct SD455 intake gaskets. In the photo I have posted the intake gasket is "squared off" on the end. I have not seen this feature on any of the aftermarket gaskets. I know I can get an aftermarket gasket that will work but I also want one that is correct in appearance.
Old 11-07-2007, 01:56 AM
2manyT/A'S's Avatar
I thought that Felpro offered an intake set for the roundport 455's?
I'll have to look & see if I can come up with a part # for you.
Old 11-07-2007, 11:41 AM
Brewster's Avatar
Brewster Brewster is offline
I have a set in inventory (spares) of a part number GR.3-270 or 1-9796613 PE2 which will work on the 1971 HO, or the 73-74 SD engine.
The repops follow the curve of the intake manifold v/s the originals which are squared off at the corners. Bottom line they both work but its all up to what your trying to acheive?
Brewster
Old 11-07-2007, 02:54 PM
toomanybirds toomanybirds is offline
The 9796613 GM gasket fits 69-70 RA IV and 71 455 HO. It does not fit 72 455 HO or 73-74 455 SD, the exhaust crossover opening is not the same size.
If you want the stock appearing gaskets for a 72 HO or a 73-74 455 SD, they are not available.
If you are patient, you can use the 71 HO gasket on the 455 SD by cutting out the center part of the gasket and using the center part from a 72-79 Pontiac intake gasket. The 72-79 will have the smaller exhaust crossover hole. The challenge is to keep the pieces aligned when installing the manifold. Some gasket adhesive and sealer would be needed.
The stock appearing gasket for the 69-70 RA IV and the 71 455 HO is still available from Car Quest, Victor and Napa. The number is MS15174. Unfortunately, this gasket set does not include the orange rings to help hold the gasket in place.
Old 11-07-2007, 10:09 PM
Brewster's Avatar
Yeah, thats correct now that you mention it. They have been sitting in my inventory for years and they even have 1971 455 HO on them.
I hope I never have to use them but if I do I'll make them work to maintain that stock appearance.
Old 11-08-2007, 03:06 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
i bought a couple sets from here last year.they are gr 3.270 part # 487078.i think these are the 72 ho 455 gaskets as they have the small exhaust crossover,but they are not squared off,they are cut at an angle.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 11-08-2007, 02:12 PM
RAM AIR 1967 RAM AIR 1967 is offline
I have a set gr.3.270 part # 487079 and are squard off on the ends and are 72 HO. I use FEL-PRO # MS90123 on 69-70 RA IV and 71 HO 455 and FEL-PRO # 1233 on 455 SD
Old 11-08-2007, 08:37 PM
GM intake gasket package 487078 fits all 72-79 Pontiac V8 except HO and SD
GM intake gasket package 487079 fits Pontiac 72 455 HO and 73-74 455 SD
Old 11-08-2007, 08:46 PM
Thanks for the replies. It would appear then that I would need the GM 487079 in order to have the "correct" appearance. If anyone has some of these at a reasonable price I would be interested. Thanks.
Old 11-09-2007, 02:16 AM
thats what i get for not checking took the person for thier word. but they may not have known either
FREEDOM ISN'T FREE
Old 11-09-2007, 10:03 AM
sdbob sdbob is offline
I used my last nos set when I tore the top off the race car. I kept the used ones. I'm using the cast iron intake.
Old 11-09-2007, 12:34 PM
I think the intack ports on the #487079 are to small to fit the 73-74 SD ports.
Old 07-24-2008, 12:30 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Has anybody recently tried to get a set of HO intake gaskets from Car Quest? I just stopped by my local store today to order a set and they are coming up as unavailable from their warehouses. Did Victor discontinue the HO intake gaskets?
Napa switched their gasket supplier to Fel-Pro about a year so thats a no-go for a source for the original style Victor gaskets now.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 07-24-2008, 10:22 AM
SD73's Avatar
SD73 SD73 is offline
I think Ken from H-O Racing still carries the proper ones as well.
