Old 01-31-2005, 07:41 PM
64catdroptop's Avatar
64catdroptop 64catdroptop is offline
Great pics. It's interesting to see how different people do things differently. I just put a TH400 into my '64 Convertible. I have a '64 389 B (February) motor, and it was drilled and tapped for a block mount starter. My question is, when did GM start this with the 389?.. Some time late '63?
Anyway, it was an easy swap and I have about a 4 page Word document of how I did the swap if anyone is interested. My linkage is different as I have column shift. And I have drawings for that also.
I used a pan of off a '64 Cadillac TH400 which has the same dipstick tube setup as the Slim Jim. For you purests.
The '64 Cadillac TH400 is setup for a bellhousing mount starter. The Coupe DeVille I robbed had a short shaft TH400. Not sure about the bolt pattern.
Suggestions on the kickdown switch? I still haven't figured that one out yet.
-r-
Never trust anything that bleeds for five days and won't die.
Old 02-03-2005, 09:26 PM
6T4gto 6T4gto is offline
As memory serves, the 389 GTO engines used the later starter mounting, and I think the '64 Grand Prixs did as well. The Bonnevilles (4-spd Hydromatic) used the earlier starter design.
Does this sound correct to the more experienced motorhead?
Old 02-04-2005, 07:07 AM
I'm not sure what automatic trans they used for the LeMans/GTO. As far as the full size: In late '63/early '64 Pontiac started to drill and tap the block for a block mount starter in prep for convertion to the TH400 in '65. In '64 thougth - GP & Cat used the RotoHydromatic, Bonneville/StarChief used the SuperHydromatic. All used a bellhousing mount starter.
-r-
Old 02-04-2005, 01:03 PM
BVR421's Avatar
BVR421 BVR421 is offline
No block mount starter pad until 64
GTOs and GrandPrixs with _manual_ transmissions got the new starter and the automatic cars got the old starter. 1965 new starter was universal.
Im using a nitrous throttle switch for my th400 kickdown on my 63
64catdroptop
there is a lot to be said for just sitting around with an uncluttered mind! LOL
Old 02-04-2005, 02:21 PM
Deadhead's Avatar
Deadhead Deadhead is offline
64CDT-
For your kickdown -
If you can not find a way to mount it on one of the carb mounting bolts (I have seen a cap screw used where they replaced the carb mounting stud with the cap screw) you could try using one off a '67 which uses the throttle linkage. I think inside the car (see previous posts on this subject on this forum). I would think that would work.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 02-04-2005, 06:41 PM
Thanks guys!
I've got my eye on a '68 Ventura that has the kickdown on the pedal. It's a complete car, with the keys in the ignition. This car as been sitting in this yard for about 15 years now. I think I'll give that a shot and let you know.
-r-
Old 02-09-2005, 05:49 AM
63RedCat's Avatar
63RedCat 63RedCat is offline
64catdroptop, I would like to have a copy of the word file. I am in the process of changing my 63 now. Did you have to modify the floorboard to fit the 400 under the tunnel?
Old 02-09-2005, 04:01 PM
RAJNWDY's Avatar
RAJNWDY RAJNWDY is offline
There might be some minor interferance with the tunnel. the Roto hydramatic is narrower in the tail shaft then the 400 and the only place that I had contact was with the upper 2 bolts of the tail shaft housing of the 400. You have to remember not to get the tilt of your engine to far out of whack. it will cause carb angle problems and driveline angle problems. I have had no problem with my setup since it's been together.
RDRR Custom Fabrications
....A fictitious company doing fictitious work....
Old 04-14-2007, 01:27 AM
RAJNWDY's Avatar
Default Yeah I'm back
After a long leave of spacing my Password and other things like moving, I'm Back to answer questions and present quotes.
And other needless information!!!
Old 11-14-2007, 08:38 PM
RAJNWDY's Avatar
Just bringing this back to the top for those folks that need to install a current trans in a older body style
Old 11-14-2007, 09:05 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
I'm going to use a console and floor shift from a 64 GP in my 63 Catalina also 73 400 cu w/turbo 400 trans. Has anybody had any experience hooking this shifter to the turbo 400?
Old 11-14-2007, 09:26 PM
RAJNWDY's Avatar
Default 64 gp shifter install
look at the pictures in this thread #s 1-6 and see how I did the same thing in a 63 Catalina Wagon!!
Old 11-14-2007, 10:00 PM
hobbygto65's Avatar
Did you change the gear selector indicator, if so how?
Old 11-15-2007, 04:14 PM
RAJNWDY's Avatar
Default gear change indicator
I found one in a 65 or 66 floor shift car and made it fit. It works fine!!
any engine after 63 will work for this change out. Like I said in the photos, all the stock componants were used, I just had to bend to clearance and make up a longer adjustable shift rod. I don't use a kick down either, because the floor shift works so nice I just shift manually. with 2.56 to 1 in the rear end, the car will go into low with no problems below 50 mph anyway. no worrys
Old 07-27-2009, 03:56 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Anyone do this and retain the column shift?? That will be the only thing that may give me fits. Thanks!
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 07-28-2009, 03:44 PM
PITTSBURGH 64 PITTSBURGH 64 is offline
I'm planning a T-400 swap in my 64 Bonneville. As much as I like the hydro, my big 500+ ft.lb. 462 is beating the hell out of the Super-hydro...
I can get a short tail T-400 from a GTO. Would this tranny be OK or would I be better off swapping it for a long tail?
Thanks,
Jeff
I plan on using a cable from the stock tree shifter to shift it. B&M sells nice ones in different lengths...
Old 07-28-2009, 04:20 PM
Depends on your Driveshaft length.
Mike
former." --Albert Einstein
- Winston Churchill
  #38
Old 07-28-2009, 06:41 PM
TININDN's Avatar
TININDN TININDN is offline
Thanks,
Jeff
I used a long tail in my '64 2+2 so as to not move the X-member forward -
Dave B.
Have the Most Fun at Pheasant Run - 2012
  #39
Old 07-28-2009, 07:43 PM
Mike
So it's possible to swap one in without having a new driveshaft made?
  #40
Old 07-28-2009, 09:47 PM
TININDN's Avatar
I think not - but I will measure if you want me to -
At a minimum, you'll need a new fine spline yoke -
Dave B.
