Old 12-27-2007, 11:37 AM
billkinney billkinney is offline
Default poa valve
I am rebuilding the air conditioning system in my 67 and cant find a new poa valve. Does this valve have anything inside that wears out ? Can I just clean it up and reuse it ?
Thanks in advance,
Bill
Old 12-27-2007, 01:07 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Off-topic, Bill, but are you from Houston?
Many years ago I knew a Bill Kinney who lived on the west side, near the Memorial Drive and Kirkwood area.
On-topic, rarely see outright failures on POA valves, but they are easily clogged up. You might try checking with one of the A/C parts specialists in Hemmings for a replacement if yours is fouled up.
Good luck.
Regards,
"455HO" Lloyd
Old 12-27-2007, 03:38 PM
I can happily say that I am not from House town..worked around it though. Head east about a hundred miles. I'll try to flush the valve first and go from there.
Thanks,
Bill
Old 12-27-2007, 07:26 PM
GStage1's Avatar
GStage1 GStage1 is offline
If you are converting to R134...your POA may need to be recalibrated.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 12-27-2007, 08:06 PM
I'm going to use r-12 just to piss off the wacko's..I mean ah ah to keep it original..yeah thats why.
Old 12-27-2007, 09:06 PM
wheelspin's Avatar
Thumbs up POA replacement....................
Hi Bill,
You might want to consider a POA upgrade kit produced by Old Air. It sells for around $90, and operates the compressor's clutch w/ a pressure switch. I have installed this unit on both of my factory air cars (GP and TA) and I have driven them them cross-country many times in July w/ the air on. I chose to stick w/ R12 as it produces consistently lower discharge temps. than the 134 conversions.
Les
ID:	115856   Click image for larger version
Les Iden
Old 12-27-2007, 09:21 PM
SSCARGO SSCARGO is offline
The valve does not have anything that wears out. It might get stuck from debris or corrosion. You can test the POA valve and if it works I would use it.
TTFN
Mat
Old 12-27-2007, 10:15 PM
As long as the valve has no parts to wear out I think I'll reuse it. Thank for all your help.
Bill
