Old 05-16-2008, 01:04 PM
Originally Posted by 455Grandville
They made several displacements for the 466 series: DT360, DT408, DT466, DT530 and now DT570. I think DT stood for "Diesel Turbo"
It started out as a farm tractor engine in 414 cid in the 1960's.
The 9.0 has some good points: easy to start when cold, and suprisingly decent fuel economy. If your friend sells that extra 9.0 tell him they are in high demand with the tractor pulling crowd.
I'll pass that one re the 9.0's.
i think you're right on the dt designation, and ih put them in everything at one time or another.
as someone else said, the dt series is the sbc in the diesel world. as long as the liner seals don't leak they run forever.
mike
former." --Albert Einstein
- Winston Churchill
Old 05-16-2008, 01:16 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
mike
If I end up buying another medium duty truck, I'll buy a 466 powered IH.
Is that R185 a 406 or 450 inliner ? They also made a 372 & 501 if I remember correctly.
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘67 Corvette 427/435
‘23 Lexus LS500 awd
‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars)
‘95 Ford F250 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles & motorcycles
Old 05-16-2008, 01:38 PM
1967Clone's Avatar
1967Clone 1967Clone is offline
The iron cranks are bad about breaking around the 2nd main cap.
If I can find a 3.9 Cummins BT I'll go that route -
A 4BT is an excellent choice, reliable power in a package that will fit your application.
Old 05-17-2008, 01:56 PM
my r 190 dump truck has the rd 450 in it. talk about a fuel swallowing torque monster!
the r 185's got a rd 372/ 374 on lp in it, supposedly overhauled shortly before it was parked. it's followed up by an overdrive trans which i want for a hauler project. it also, curiously enoguh has air brakes on it. if this thing's tight enough i may stuff a dt466 in it and run it.
what i was initally on the hunt for was a 50's "s" series cab and clip to swap over on to an 1800 series school bus chassis.i had a NICE 54 r160 bought and the guy backed out of the deal at the last minute on it.
as you can tell binders hold a serious interest for me also.
addictions are terrible!
mike
- Winston Churchill
Old 05-17-2008, 11:02 PM
mike
Dont they have the Scout Nationals in Indiana ?
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-17-2008, 11:17 PM
Im told many give good service and fuel economy in step vans; what kind of hp/torque can they make ? They make 6.2/6.5 conversions for Land Rovers, but if I could find a good 3.9 for a reasonble sum Id go that route.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-18-2008, 01:38 PM
1967Clone's Avatar
They can be hopped up just like their big brother 5.9. Pumps, injectors, turbo...I'd get a P-pumped engine if you're looking for power. You can get 350hp/500 lb/ft pretty easily from what I understand.
I was going to put one in my FJ40 until I got a steal on an LT1.
I was going to find an aluminum step van, take the 4BT and cut the body up for scrap and try and break even.
Good forum here,
http://www.4btswaps.com/forum/index.php?
Old 05-18-2008, 03:23 PM
i don't know about the scouts but the ih nats are held in springfield, oh. it's about 2 hours from me.
mike
- Winston Churchill
Old 05-18-2008, 03:27 PM
i really need to get on repairing the floors in my diesel scout. it's the first one that ih engineering dept in ft wayne stuffed a nissan diesel in. i know the guy who bought it intitially from havester. it should pull a little better than 30 mpg.
- Winston Churchill
Old 05-18-2008, 07:51 PM
mike
One of these years I need to go see that. . . . .
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-18-2008, 07:52 PM
Good forum here,
Thanks, hell 200 hp would be more then enough for what I have.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-18-2008, 08:33 PM
1967Clone's Avatar
That little nissan will get 30 easily from what I've heard.
I had a gasser scout II awhile back, I always dug the binders for their 4x4's.
Old 05-18-2008, 09:23 PM
They used the 6-33 in forklifts and other industrial applications.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-19-2008, 06:21 AM
1967Clone's Avatar
Speaking of forklifts, I just pulled a 2F out of my fj40, and it was propane powered.
Old 05-22-2008, 06:48 PM
Good forum here,
Im already sold on that engine; now I just need to find a reasonably priced one.
The old Landcruiser 6 banger sure has a striking resemblence to the old Stovebolt Chebby'
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-22-2008, 09:53 PM
RA6T7GTO's Avatar
RA6T7GTO RA6T7GTO is offline
Send a message via AIM to RA6T7GTO
i have a 1998gmc with a 6.5 turbo diesel i use these guys for parts and info
http://www.ssdieselsupply.com/index.html
1967 RAM AIR GTO 1 OF 156 AUTOMATICS
Old 05-23-2008, 07:05 AM
1967Clone's Avatar
So much in fact, I converted it to a GM HEI I pulled off a 77 Nova inline 6. All I had to do was swap the gear and have the flange machined off. I believe the oil pump is a bolt on too. The one I pulled from my cruiser has well over 300K on it.
  #38
Old 05-23-2008, 07:58 AM
RandyW's Avatar
RandyW RandyW is offline
The Toyota engine was knock off of the Chevy, GM sued them and collected fees for every one sold.
Randy W 1975 Firebird third owner. 1980 Grand Am/black/beaurdeaux/45000 mile original owner.(Now belongs to Iowapub.) '67 Impala SS (sold)
  #39
Old 05-23-2008, 08:05 AM
RandyW's Avatar
I had a 1982 Suburban with a 6.2. I bought it in '89 with a blown engine, the oil plug got left out at Jiffy Lube and it still went 20 miles before it broke! When I got all I could find was an engine from a medium duty truck, I used that, got a buddy that worked for Mack to tune it for me. That thing would smoke a 454 3/4 ton truck, both figuratively and literally! It was a 4x4 and would smoke the rear 32/12.50 BFG's with only 3.42 gears. It had a 700R4 from the factory but the torque killed 3 of them so I went to a t-400 until I got a pro built 700. A couple of years later a hurricane dropped a huge limb on the truck and totalled it. I put the whole drivetrain in my '75 Scout II. Talk about a beach burner!!!
  #40
Old 05-23-2008, 09:17 AM
1967Clone's Avatar
Except the "knockoff" was much more reliable than the original
Have a link to where they sued?
