Old 05-31-2008, 03:47 PM
tripwr1964's Avatar
tripwr1964 tripwr1964 is offline
Question 1.25" front sway bar on '64 gto
trying to install a 1.25" aftermarket sway bar from PST. having a couple of problems. 1) mounted in the stock position, the sway bar hits the idler arm. 2) also the end links (bit longer that stock) seem to be impossible to install. they interfere with the uppper ball joint nut. i cut them down ~1/2" and still can't get them on.
Question: do i need to drill another hole in the frame to slide this thing back a bit? don't see any other way around this... thks Tim
Old 05-31-2008, 07:24 PM
Hurst65's Avatar
Hurst65 Hurst65 is offline
It takes some effort to get it mounted. How do you have the car supported now? Is it sitting on stands under the frame and front wheels hanging down???
1965 GTO, 408 tri-power, 4 speed, Currie 12 bolt w/3:42's, Hurst wheels
Old 05-31-2008, 07:26 PM
Hurst65's Avatar
Don't drill any holes.
Old 05-31-2008, 10:06 PM
tripwr1964's Avatar
yes. front is on jackstands wheels hanging.
my retainers/clamps dont allow for any fore/aft movement. they are slotted, however, my bolts both end up on the inner most position in the slot. hence, no adjustability and it hits the idler arm.
Old 06-01-2008, 08:46 AM
Hurst65's Avatar
okay.... try this.
With the car still on stands. Put your floor jack under one of the lower control arms and raise it up to almost a normal height or until the spring starts to take most of the weight on that side. Then see if you can get the end link installed for that side. Then go to the other side and repeat. Will help alot if you have a helper to work the jack and you guide the bar and endlink into its place.
Once you get the both endlinks tightened up and get the full weight on the front suspension you should be okay.
Hope this helps.
Old 06-01-2008, 08:51 AM
Hurst65's Avatar
There should be very very little fore or aft movement of the frame mounting bracket. With a big bar like the 1.25 there just isn't much room left for those brackets to move. Notice how much less bushing material on the sides there is with the bigger bar??
You using poly bushings?
Old 06-02-2008, 08:40 AM
allpawl allpawl is offline
What application is the bar for, i have a gm unit 1 1/4 on my 65 w/no interference or insall problems.
Old 06-02-2008, 02:52 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
I also have a 1.375 GM style (HO Racing) front bar, with no interference issues AT ALL with the idler arm......
What brand of bar is it? Pics?
"XE cam basher"
Old 06-02-2008, 05:34 PM
"I also have a 1.375 GM style (HO Racing) front bar, with no interference issues AT ALL with the idler arm......"
Me three! No issues when I installed either the 1.25" bar or the 1.375 HO bar on my 64 GTO.
Old 06-02-2008, 07:25 PM
tripwr1964's Avatar
I think if I had the stock idler arm on, which is smaller, it would be fine. The piece a got from PST is a bit beefer. I'll take some pictures. thks tim
