WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 1993-02 Firebird/Trans Am Owners > 93-02 Interior Tech
93-02 Interior Tech OK, so who's door panels Aren't cracked?!
Old 08-03-2008, 03:03 AM
esahlin esahlin is offline
Default 2002 TA power seats
I haave some 2002 TA power seats (both power tracks and lumbar) I am trying to put into a 68 FB....does anyone have a wiring diagram that shows how to hook up power to the seats? Or maybe you just know of the top of your head how to do it?
Old 08-03-2008, 09:47 PM
judgethis judgethis is offline
I have the schematics I just dont know how to move them around on a computer. So Ill try to explain. Do you have all the connectors to go with the seat track from the switch to the track motors? Power is supplied to the seat track switch at terminal F (orange wire) and ground is terminal C will be ground (black wire).
For the lumbar: supply power to terminal A on the Seat Cushion Air Control Module connector. Ground is supplied to terminal D of the module. Supply power to the F terminal of the lumbar switches.
Hope this helps.
Old 08-04-2008, 12:08 AM
Thanks for the help....all the wires and connectors are all hooked up for the seat motors and lumbar stuff. You lost me on supplying power to the lumbar connectors. Beccause I dont have a way to tell what the different terminals are. I can really on go by wire color. I'll take a pic of the bottom of my seats and the connectors so that maybe that will help you tell me what to do. I'll post it here.
Thanks for helping me out.
Old 08-05-2008, 08:42 PM
Larry P's Avatar
Larry P Larry P is offline
This is the body side of the under seat conn. Hope this helps
Connector Part Information
• 1206-4752
• 6-Way F Metri-pack 280 Series (BLK)
• 1206-4754
• 6-Way M Metri-pack 280 Series (BLK)
Pin
Wire Color
Circuit No.
Function
Pin
Wire Color
Circuit No.
Function
A
GRY
764
Driver Seat Deflate Relay Control
A
GRY
903
B
WHT
766
Driver Seat Inflate Relay Control
B
PNK
904
C
ORN
1240
Battery Positive Voltage
C
ORN
1240
D
BLK
1450
Ground
D
BLK
950
Ground
E
BRN
763
Driver Seat Pneumatic Lumbar Solenoid Control
E
PPL
905
F
PPL
765
Driver Seat Pneumatic Lateral Solenoid Control
F
RED
906
Old 08-05-2008, 11:39 PM
judgethis-
I took a closer look at my connectors and saw where they are labeled with the letters....thanks for pointing this out.....I just hadnt looked close enough yet so now I will be able to follow your directions.
Larry P-
Thanks for the info....it helps out alot.
Featured Vendors
Advertising Info
