Old 08-31-2008, 06:24 PM
jdh421's Avatar
jdh421 jdh421 is offline
Dont forget that little ball stud on your AFB. You should be able to unbolt it and bolt it to the center carb to hook your throttle bar to. Most Tri powers came from A-Bodies and had a little nub to hook the accelerator cable to. It will not work on the big cars. The ball stud is a must. You will LOVE the tripower on your big car ( not the mileage however). Jeff
1966 Catalina Convert
1968 Firebird 350
1969 GTO
1967 Bonneville 4 Dr Brougham 428
1967 Bonneville 2 dr
1959 Buick LeSabre 2dr
Old 09-03-2008, 11:25 PM
65FATCAT's Avatar
65FATCAT 65FATCAT is offline
What is this dag 213 stuff? Mine don't have it, do i really need that and if so where do you get it and how do you apply it?
I need close up photos of stock 66' tri power setups as installed, need both sides but especially need to see the linkage area from the firewall to the carbs, all i have now is the carb to carb sliding linkage, no manifold brackets, throttle rod or anything from the carbs to the firewall, i have no idea what is supposed to be there and how it all hooks together.
I'll post progress pics soon, thanks. Also, what is the diff. btwn gto and big car tri power setups if any?
Old 09-05-2008, 07:18 PM
Deadhead's Avatar
Deadhead Deadhead is offline
You will also need one that has at least a 3/16" + shoulder on it. Hard to find, but you can make one. IME without this, the rod is not at the correct angle to the carb., & it causes Probs.
My end carbs leak occasionally, but no other issues on mine. I rebuilt the whole mess myself with no issues. Had to take it all off a 2nd time to go through it all again to get it exactly right. It is cool, but I think the right 4bbl romps better. Not the same eye candy or war wooping when you open it up though.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 06-22-2009, 08:23 PM
Geeto-Tiger Geeto-Tiger is offline
as for my setup... i'm about $300-400 away from the rest of parts I need (sounds like a lot but it's just a few small things here and there that add up)... More importantly I have a 65 setup and a 64 engine so I my manifold won't work with it.. This really slowed down my install :-)
Mike,
Did you ever get it installed? If not yet (because of the heads), maybe I can assist you:
-I have a 64 intake you can use your carbs on
-I have 65 heads; #76
Gary
