Old 01-31-2009, 12:27 PM
ta man ta man is offline
I definately want one when they are done.
Old 01-31-2009, 10:16 PM
Doug1's Avatar
Doug1 Doug1 is offline
If you need another volunteer, I'm it! 79 TA. I asked you about getting one of these about 2 months ago :-)
Old 02-14-2009, 12:02 PM
GTOLou GTOLou is offline
I think this sending unit is fine, just like it is. My car/tank has this extra tube for AC. Without this tube it is a breeze - the car HAS a deep indentation between the mounting rails for the tank. I think Rob set up the unit to have the two fittings come out exactly halfway between these two. An AC car has this extra tubing that gets in the way - but is still no big deal.
The sending unit fit fine in the stock tank (the only minimal thing is that the negative ground is about 1" too short (LOL) - no big deal obviously).
Here are pics - ask questions - I think this unit is ready.....
ID:	157996   Click image for larger version
ID:	157997   Click image for larger version
Old 02-14-2009, 12:07 PM
The pic from the top - the sending unit needs to be as close to halfway between the rails as possible (I adjusted this - the AC tube hinders this a little).
Also - it is a little cramped once the tank is in - it is better to get your an-lines on there before you mount the tank.
I have a cheap brass fitting on the return I will just use a rubber line for this.
My plumbing is still evolving.
ID:	158000   Click image for larger version
ID:	158001   Click image for larger version
Old 02-14-2009, 12:15 PM
The other thing to cover here is thanking PY for letting us put this stuff on their forum.
