Old 12-03-2008, 08:41 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Default Driveshaft length and type
Anyone here know what length driveshaft I will need with a TH400 and a 12 bolt in my 78 grand Am? I will be running 1350 joints on both ends with a loop, is 3-1/2" steel the way to go or how about aluminum? Do I need 4"? What are some of you running? I know the longer the driveshaft the lower the suggested rpm, I imagine I will be spinning around 6000 max. Any help is appreciated. -Jim
Old 12-04-2008, 04:07 PM
shotgun shotgun is offline
PY Staff -Tech
Mine is a th400 going to a 12 bolt out of a 68 Chevelle , center to center of the joints is 51 7/8".
The D/S 3.5" and my D/S guy says it can handle 1000hp, I am only hitting it with 625hp.
It is a heavy sucker at almost 25#, when/if the budget allows someday I will go aluminum(approx. 14#).
That's 10# of rotating mass removed.
Carbon fiber also looks neat , getting close to single digit weight , but the price.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date [email protected] mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
Old 12-04-2008, 08:22 PM
DiamondJim's Avatar
Thanks for the info. -Jim
Old 02-14-2009, 03:56 PM
DiamondJim's Avatar
Shotgun, if you are out there, do you think 50-5/8" center to center will work for me? Thanks -Jim
Old 02-14-2009, 09:50 PM
455_regal 455_regal is offline
I looked at all styles...I choose chromemoly because its suppose to be stronger and lighter then mild steel. some companies list a 3" at 800-1000 hp.
PONTIAC POWER
