I have an original base plate from a '74 GTO. This is the steel plate that is actually the top portion of the air cleaner. Some surface rust. Can email picture. Asking 125.00 + actual shipping. I am located in WV, 25271.
Can you post a picture of that baseplate? Not sure what it looks like. I might try making one up at some point for mine.
Denn die toten reiten schnell More doors = more love!
Ahhh crap. It WOULD have to be complicated like that. Ehh. Ill try someday anyway.
Did some of these shakers have Vac operated flaps in the back? The one I have has plastic covers.
'70-'72 T/A's used a dual solenoid(controlled by switch on throttle lever on carb.) The '74 GTO had a single solenoid(controlled by a vac/elec switch remote from carb.)
The flapper door on the inlet side of the shaker is metal covered with a thin closed cell foam padding on the side that faces out. I was going to use this for my '74 SD to make it as Pontiac would have done, if not for the drive by noise standards. I ended up getting a complete shaker in much better shape and transfered the top of the TA's shaker to the bottom of the other one. If I don't end up selling this I'll probably set up another spare for the T/A. |
Does anyone know where i can buy a new shaker hood and the shaker assembly? Does anyone sell new body parts specifically for the 74 GTO/Ventura?
