I have a 1975 455 4 speed car I am restoring. The gauge cluster looks to be incorrect, the speedo is 160 mph, and the tach is 8000 rpm. Are either of these correct for a 1975 Trans am ? Everything else in the dash is original such as radio , 8 track player etc, so it has not been a torn apart car. What speedo and tach should be in this car , the 100 mph speedo, and the 6 K tach ? TIA, Craig
What is the tach redline? What are the readings on the water temp gauge?
the redline starts at 5750 and goes all the way to 8000 (of course). The water temp is 100, 220, 260. The other thing I am wondering is , my 160 speedo has the two holes at bottom for the brake light, and the fasten seat belt light,as the 75 -79 100 MPH speedos are. All the 160 speedos I have seen only have a rectangular single hole for the brake light. Any idea what I have, did the factory make the 160 speedo with the two indicator light holes ? Craig
The speedo in your car came in mid 1972-1974 Firebirds. The speedo with the single brake warning lamp came in 1970-early 1972 Firebirds.
1975 Firebirds would have come with a 100 MPH speedometer.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
How early in the '75 model year was the car assembled? The 100 220 260 suggests a '74 package (maybe late '73).
The 75 speedo cluster came with the 8k tach and the same water/oil gauge markings as a 74. The only difference is the speedo in the 75 was 100mph and the 74 was 160mph. The speedos can be swapped out real easily in the clusters as the speed is only held in by 2 screws in the back and the plastic cover.
I have a 100 MPH speedo out of a 75 Formula if you need it, the rest of the of the cluster is in my 74 with my 160 speedo.
74 Formula Below motor destroyed fall of 2023 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet 75 Formula 400 / 4-SPD matching numbers |
I will swap you mine...I have a 100 Speedo and 6K tach...always hated it, want the 160/8K
