inside the lower rear seat springs
under front seat carpet inside front seat spring under rear carpet partly on top of the hump remember theres a body broadcast and a build sheet. |
| The Following User Says Thank You to Cammer-6 For This Useful Post: | ||
What's the difference between them?
69 Z 302 M21 3.73 http://www.byjanmarie.com/camaro/Z28.html 69 FB 400 http://www.byjanmarie.com/firebird/69.html 69 Camaro 327 4sp. 4.10 http://www.byjanmarie.com/camaro/69camaro.html ( SOLD) 2002 Camaro LE/SLP-(sold) 1967 Nova SS-- 327, M20, 3.73, FRT Disc |
My 67 had a nice copy under the springs of the rear seat and remnants of the same copy under the front seat between the pass front bolt of seat bracket under carpet.
69 GTO 67 Firebird 400 |
One was Fisher Coachworks the other was PMD
Under rear seat, in rear seat cushion, in rear seat back cushion, under RH front seat, under carpet (front- RH), under rear sound deadner (RH), RH front seat between frame & bracket.
Most of sheets found will be the BODY BROADCAST COPY. Very rare to find the CHASSIS BROADCAST COPY (especially on 67-68). BODY B/C: Used by Fisher Body CHASSIS B/C: Used in Final Assy (Chassis related operations) Even more rare than these two sheets is an inspection sheet (have only seen one). Also have found sheets from vehicles built before/after subject vehicle. Also have found partial sheets and blank sheets.
John '68 Firebird Ram Air 4-spd Conv. John 14:6 Semper Fi
| The Following User Says Thank You to RA1John For This Useful Post: | ||
John - those inspection sheets (with the punches in them) were legal documents (that is, had specific record retention requirements) and were not supposed to get out. That's probably why you've seen only the one. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
When you say in rear seat cushion,Do you mean in the springs or actually inside the cover and hog rings? I have also seen them behind the seat backs in the front seat. Never under the covers though has anyone else seen them under the covers and inside the seat?
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
I found both of mine under the rear seat bottom between the springs and the burlap.
One in rear seat springs, one under front carpet, and one behind driver set back.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Fisher used the UOIT (Uniform Option Information Tag). Those are rare to find. The body sheet followed the body, chassis sheet was used in the engine dress and chassis areas. Neither were used by Fisher. http://www.camaros.org/assemblyprocess.shtml#chev (updated with new pics). I don't think the inspection sheets were legal documents. They documented the buy-off of the car by the various dept's and helped keep track of necessary repairs. JohnZ will know for sure. |
| The Following User Says Thank You to Kurt S For This Useful Post: | ||
Found a few of those,its neat to see the options spelled out with X's
My recollection is that they had to be kept for 10 years; that they were a "discoverable document" during any legal/recall investigations against GM and could be used as evidence in a court of law. At least that's what I think I remember from my days at Chevrolet Flint Assembly (1979-1986) - K
