Old 04-30-2009, 12:15 AM
john5670 john5670 is offline
Default Dynoed 461
Today we put my dads 461 stroker on the dyno. I will post a video and the dyno sheet soon. It peaked at 584.1 HP and 564.4 Trq. at 6000 rpms. This was with Butler 316cfm heads, mild roller cam, Performer RPM intake (port matched), 1 inch spacer, Holley 950 HP, 10.0 to 1 compression, and 92 Oct. fuel. This will be a street car with a TKO 5 speed and 3.43 12 bolt rear end. Wheeler racing in MN machined and assembled the motor and Butler supplied the engine kit. I would have to say Gary at Wheeler really knows his stuff I am definitely pleased with having him build the motor. Also working with Jim Butler was a pleasure. I thought I would post these results for those interested.
Old 04-30-2009, 01:45 AM
GOAT490's Avatar
GOAT490 GOAT490 is offline
Thumbs up
Sounds like a FUN combo! What kind of car is it going in?
PHILLYGOAT
PHILLYGOAT
1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/
3550lbs/ Full Exhaust/ Foot Braking
1.41 60ft [email protected] [email protected](Pontiac Heaven)
More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379
GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4
Old 04-30-2009, 07:52 AM
rad400 rad400 is offline
Sounds like a winning combo from the Butlers. Good luck with the motor and what ever ride you put it in.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 04-30-2009, 08:06 AM
grandville455's Avatar
Nice Numbers!!.. U guys bringing it to the Rock?
Darby
M/T 275/60 ET SS Drag Radial
Old 04-30-2009, 08:24 AM
gearbanger's Avatar
gearbanger gearbanger is offline
Nice numbers. Would you mind to give the cam specs?
Old 04-30-2009, 01:07 PM
Default Attached Photo's and Dyno Sheets
Everyone,
I have never posted pictures before, hope it works. I will post the cam specs soon too.
ID:	167057   Click image for larger version
Name:	Dyno Sheet 1.JPG
ID:	167058   Click image for larger version
Name:	Dyno Sheet2.JPG
Old 04-30-2009, 04:54 PM
Default More Dyno Pulls (2500 rpm to 4600 rpm)
Its going in a 1967 firebird convertible. The car is currently being preped for paint. Does anyone know if these are good numbers (average, below, above). This is the first motor I have built.
Name:	Dyno Sheet4.JPG
ID:	167086   Click image for larger version
Name:	Dyno Sheet3.JPG
Old 04-30-2009, 09:22 PM
gearbanger's Avatar
Those are good numbers. Looks like about average or a little better for a pump gas streetable 461. I am actually surprised that the torque is lower than the hp, but your hp is a little higher than alot I have seen so you may be starting to trade low rpm power for extra high rpm charge. I am going to go out on a limb and say that engine may benefit from a Torker II intake with a 1 inch spacer. It seems you are about at the point where a RPM starts to give up a little to the Torker.
