Old 07-28-2009, 01:11 PM
FFD FFD is offline
http://www.mark7radiators.com/ hit spec form you kinda can see what you need
Old 07-28-2009, 11:59 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
I used a northern rad race pro 19 inch for my 64, it's a cross flow 26 x 19, 19 high and 26 across. They also have a custom fan shroud kit u can buy with it. Used stock 3 core upper and lower mounts, with 2x3 aluminum tubing for a filler in the bottom, and aluminum filler channel in the top, (also northern rad supplied,). Custom fans shroud was welded together by local welder.
ID:	176380   Click image for larger version
ID:	176381   Click image for larger version
64 Lemans hardtop
4spd, buckets
