Old 09-16-2009, 08:54 PM
steve's Avatar
steve steve is offline
Default did you paint your E-heads....
....and more importantly were you happy a few thousand miles later ?
Old 09-16-2009, 08:58 PM
mysticmissle's Avatar
no but i painted my cv1s and think they look fine!
Old 09-16-2009, 09:02 PM
GTOLou GTOLou is offline
What do most guys do to get rid of the logo? Just take a grinder and grind it off?
Old 09-16-2009, 09:08 PM
steve's Avatar
how does the paint hold up on them compared to iron ? any different prep ?
Old 09-16-2009, 09:21 PM
Doug1's Avatar
Doug1 Doug1 is offline
Mine are painted. The still look perfect. No discoloration after 2 years.
Old 09-16-2009, 09:22 PM
steve's Avatar
wow ! how did you prep them ? lots of thin coats of paint or one thick one ? details please !
Old 09-16-2009, 09:23 PM
Doug1's Avatar
http://forums.maxperformanceinc.com/...91#post3763791
Old 09-16-2009, 10:20 PM
4dblnkldude's Avatar
F no. The point? Do you store your car outside in saskatoon, saskatuwan outside in the rain and snow? Do people think that they are fooling someone? I've had mine on the car for 4 years now and 12,000 miles with slight discoloration.
Old 09-16-2009, 10:32 PM
steve's Avatar
i guess some folks just like the seamless look of everything painted the whole way...show us pics of yours ....
Old 09-16-2009, 10:52 PM
guccieng's Avatar
guccieng guccieng is offline
painted semi-gloss black. i love to see people cringe! motor is new, so we'll see about the test of time. prepped with denatured alcohol and sprayed with 3 light coats.
John J.
Old 09-16-2009, 10:59 PM
Doug1's Avatar
Brake cleaner to start.
Engine Primer 2 coats
Engine Paint 3 coats.
I used POR20 aluminum color paint to recently paint the ARP head bolts. They were begining ot rust. I used regular paint on one side and POR20 on the other to see which I liked best. I like the POR20 painted bolts better. Every other external bolt is stainless.
Old 09-17-2009, 01:23 AM
65gto69's Avatar
65gto69 65gto69 is offline
I have mine painted, left the Edelbrock logo in tact. I don't have near the miles as some do, I am only looking at about 50-60 miles since my motor has been built about 2-3 years ago, but I do have a lot of idle and tuning time on them which still produce heat and mine still look good.
Not to mention the aluminum on my E-heads was starting to discolor from age, so decide to paint them my baby blue 65 engine color. People at the local cruises don't know what is going on with my motor. They scratch their head because they know it doesn't look right but they can't figure it out.
What gets me is I have many people asking me why I put a BBC in my car????? I tell them it is all Pontiac and end up arguing with them.
Why do people do that, sheesh......
Cast heads would have been turning brownish-white by now
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 09-17-2009, 01:30 AM
Danimal's Avatar
Danimal Danimal is offline
painted mine too. no real prep work. still pretty good for the most part two years and 800 miles later.
would'nt do it again though.
Dan
Austin, Texas
Antique Gold 1969 Pontiac GTO YS400/TH400 3:23 10-bolt
2009 Pontiac G8 GT Maverick silver/Black Interior
1997 Chevrolet S-10
Old 09-17-2009, 02:10 AM
428 78T/A's Avatar
428 78T/A 428 78T/A is offline
I just can't find the right Hi-Temp light blue in the color I want.
"When you tell somebody something, it depends on what part of the United States you're standing on as to just how dumb you are".
2008 Tundra Double Cab 4x4 TRD (5.7 381 hp)
1978 Trans Am w/69 428 (343hp/452 FPT)
1999 Black T/A, M6 (allegedly stock 325hp)
Old 09-17-2009, 02:42 AM
Tin indian GTO's Avatar
Tin indian GTO Tin indian GTO is offline
Painted mine when I wanted the motor to look sleepy.....milled the front of the heads so the edelbrock was gone and the took a 30 grit grinder disc and hit it with a hammer to give it the Cast look, Did the same with the intake. Also ground off the edelbrock on the exhaust. Painted the distributor cast and all the billet pulleys black.
ID:	181537   Click image for larger version
Last edited by Tin indian GTO; 09-17-2009 at 02:44 AM. Reason: added more description
Old 09-17-2009, 11:26 AM
Donovan Donovan is offline
nice... I like your ingenuity.
Old 09-17-2009, 01:05 PM
My thoughts were, aluminum is porous, and it might last longer if it's sealed. And when it comes to touch-up, painted makes it easier. Mask and shoot and it's done.
I didn't prep mine at all, mainly because the stuff I had was dried up and didn't know it until I popped the lid! I had some of that high heat stainess steel exhaust stuff from eastwood. Used to use that on iron heads exhaust ports to prep before painting, made them last a long time before having to reshoot them. Figured I'd try it on the aluminum heads too, just didn't work out that way!
Old 09-17-2009, 01:43 PM
66 LeMans's Avatar
66 LeMans 66 LeMans is offline
I really like those braided lines!!
What would be a good manufacturer to order these from?
If you don't like the way I drive, get off the sidewalk.
Old 09-17-2009, 03:18 PM
fuel lines or pan evac lines?
Old 09-17-2009, 05:15 PM
66 LeMans's Avatar
Actually, I want to change all the lines eventually.
What I would like are the lines needed from the fuel pump to the carb.
(I am using a high flow mechanical pump, a performer intake and a 600 cfm edelbrock on a 1966 389 engine).
I also would like to change the radiator hoses.
Actually, I would love to change all the rubber hoses in the engine bay.
