#41
Old 01-14-2010, 11:49 PM
notime's Avatar
notime notime is offline
Actually, those were primer pics from yesterday, my guy sanded and painted it today.
  #42
Old 01-15-2010, 12:24 PM
Dave from England Dave from England is offline
Default 67 Firebird Restoration
Can anybody tell me what this is or what these are, there are two of them, and where do they fit?
Before coming across these, I read somewhere on a previous post that they were rebound stops for the sub frame lower A arm snubber. Which means absolutely NOTHING to me!!!! For a start, I don't even know what a snubber is!
I have looked in all my manuals and on the illustrations for the fron suspension, I cannot see them anywhere. So, can some one please enlighten me in very simple terms, or with a photograph or illustration?
Thanks, Dave.
Name:	what is it.jpg
  #43
Old 01-15-2010, 09:05 PM
Birdguy's Avatar
Birdguy Birdguy is offline
[QUOTE=but thanks anyway guess Ill have to rely on someone very knowledgeble to read my post Im sure theres someone out there that has an answer without having to rely on code numbers stamped on a rim its got to be more technical and accurate than that[/QUOTE]
Funny how with my not being knowledgable that a couple of posts later another member sent you the same fargin' link that answered your question. You have a wonderful way with words, old chap. Here's a photo that should answer your question, even with my lack of knowledge.
  #44
Old 01-15-2010, 09:32 PM
guccieng's Avatar
guccieng guccieng is offline
that's a '67 only type bump stop that had a removable snubber. it's for the lower control arm bump stop to contact the frame during full suspension compression. notice how the bump stop lines up with the snubber? in '68, the bump stop was moved to the rear of the lower control arm and the snubber was welded to the frame. in '69, the bump stop was still on the lower control arm, but moved to the front, along with the snubber on the frame.
John J.
  #45
Old 01-16-2010, 08:26 AM
Hey Birdguy
Thanks for the picture been & had a look at the car and yes theres a place for it a mounting bracket with a hole in it thats all now is this whats called a snubber as Im getting confused between bump stops & snubbers? With regards to the wheels I think youve gotten hold of the wrong end of the stick.I checked out that link on the fisrst gen site BEFORE I did the post as none of my stampings corresponded to what they had logged & what I was saying was that G M must have had a more technical way of telling what would fit what other than the stampiings.Yes the other guy did send me the same link but thats not what answered my question it was when he said ALL WHEELS WILL FIT DRUMS & I have drum brakes. So if you took offence to my post none ment as I need all the help I can get
  #46
Old 01-16-2010, 08:36 AM
Thumbs up 67 Firebird Restoration
Thanks GUCCIENG
After reading your post several times I now understand what your saying that the two little components I have are called snubbers (correct ?) Dave
  #47
Old 01-16-2010, 12:55 PM
guccieng's Avatar
correct: bump stops on the bottom, snubbers on the top.
John J.
  #48
Old 01-20-2010, 07:06 PM
notime's Avatar
Heres a couple new ones for ya dave. Havent got to work on it till today, waiting on parts and paint to dry. Body is at the blasters.
ID:	194527   Click image for larger version
ID:	194528   Click image for larger version
ID:	194529   Click image for larger version
  #49
Old 01-22-2010, 07:41 AM
Can anyone tell me what this is?
Not sure if it's off my '67 Firebird convertible, or my '59 Chevy Impala 2 door hardtop.
Sent items for both cars to powder coating and they came back all mixed up!! I have been able to identify everything else except this!
Dave from England
ID:	194762   Click image for larger version
ID:	194763   Click image for larger version
  #50
Old 01-22-2010, 07:47 AM
I found these in the box along with my seat track and other items for bucket seats. Not sure what they are, but looking at various catalogues, they look like seat track extenders. But, what makes me doubtful is that this car was imported into the UK in 1982, and then spent some time in Spain before coming back to the UK.
I have owned it since '95, and I certainly haven't bought any seat track extenders, which I believe are a fairly recent adition to the parts catalogue. So, I would appreciate assistance.
Dave From England
  #51
Old 01-22-2010, 10:11 AM
8point 8point is offline
Send a message via ICQ to 8point
Yes they are seat extenders. some 67's had them originaly.
  #52
Old 01-23-2010, 02:24 AM
notime's Avatar
Dave, those bolt to the floor, then the seats bolt to them, they were in the car i;m doing. As far as those little pieces, i dont remember seeing those anywhere, however, i wasnt the only one disassembling the car. Here is a little magic for ya.
ID:	194870   Click image for larger version
  #53
Old 01-23-2010, 07:09 AM
thanks for that 8point I wasnt aware that it was a factory option just thought I was an idea that some tall guy had come up with & then others had taken it onboard Dave
  #54
Old 01-23-2010, 07:38 AM
Hey notime Ive only got two of the seat extenders so I guess they are both for the drivers side only (correct?).With regard to the other thumbnail pics its only one item taken from different angles.Not with the majic bit just looks like youve got the body on a rotissorie & taken a picture of part of the tail panel or Im I just too thick to see what Im supposed to be looking at.I see youve now started cheating trying to catch me up with your restoration by having someone help you (lol). I read on another thread tha your having trouble with theives & you say the cops cant catch the well why not install closed circuit TV may be an unwanted outlay but its got to be les expensive than keep buying new parts. Took some pics of the new upholstery will post these on Monday or should I say my daughter will when she;s back here at work. Dave
  #55
Old 01-23-2010, 11:54 PM
notime's Avatar
As far as the seat brackets, i didnt take them out, so i dont know if there is 2 or 4, come to think of it, i only remember seeing 1 pair, so maybe your correct, i'll find out on monday.The first pic shows the tail panel is pushed in pretty good, second shows it back in shape. Cops say cameras are worthless unless you know the person, they wont pick up license numbers and you cant blow up a digital picture cause it pixels too bad, my alarm guy reluctantly said he's right, so i've just decided to finish fencing the area off so they cant get in. The only thing i lost that i really needed were the steering arms for the firebird, everything else was junk, but it was good junk!
  #56
Old 01-24-2010, 05:03 PM
Birdguy's Avatar
Get yourself a rabid pit bull with aids and a bad temper. Or a female lawyer.
  #57
Old 01-24-2010, 05:06 PM
guccieng's Avatar
or ex-wife on a chain!
John J.
  #58
Old 01-25-2010, 12:41 AM
notime's Avatar
I dooo have an x-wife, i would love to chain her up out there! and she is mean as a rattle snake, but then she would probably call her laywer and get another restraining order on me that the f----n democrat n-----b---h magistrate would believe every lie she tells them. Ok, sorry, got a little carried away there, you got me started on x-wife. I've decided to finish fencing the area in and put a gate on it, they wont steal what they cant see, but then again???
  #59
Old 01-26-2010, 12:26 PM
Hey Notime,
Here's the new covers on the rear seats. Same covers are on the front seats. They are PUI covers and I will also have new door panels courtesy of Al Nkoch of El Passo, Texas. I am told he makes the best. How's progress with yours?
Dave From England
  #60
Old 01-26-2010, 12:29 PM
Can anybody tell me with absolute certainty which gas filler door is correct for my car?
It is a last week in March build so it is fairly early. I read contradictory reports. Some say that the early build '67's had the flat door and later went on to the finger pull and then in '68 they went to the flat door again. Others say finger pull for all '67's, flat door for '68's.
The reason I need to know is somehow I managed to loose mine and need to replace it, so help in needed to help clear this up.
Dave From England.
