Old 02-14-2010, 03:39 PM
Zirconia Zirconia is offline
Originally Posted by se428bandit View Post
Yeah,i guess it was.Is that your car?
No, not mine. I wish it was.
Old 02-14-2010, 04:33 PM
2manyT/A'S's Avatar
Default Frankenbird/Hermaphrodite!!!!!
Originally Posted by RAFormulas View Post
Not to mention that it's a WASTE of a perfectly GOOD hood!
Just say NO!
Those pictures should NOT be permitted on these forums.
(where are the Mods when you need them?)
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
Old 02-14-2010, 04:58 PM
bird72's Avatar
bird72 bird72 is offline
This is what God does to people who put shakers in Formula hoods!
72 Bird
Old 02-14-2010, 05:14 PM
2manyT/A'S's Avatar
Never really cared for flames on cars (or hats,shirts,running shoes,etc.)but I gotta say that after seeing this picture,I'm "warming up" to them a bit.
Old 02-14-2010, 11:04 PM
LeighP's Avatar
LeighP LeighP is offline
man, they sure make those flame jobs "lifelike".....
thats clip from Chips makes me shed a tear......
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 02-14-2010, 11:20 PM
fsted fsted is offline
one thing is for sure with a shakeula hood you will be the only kid in the neighborhood with one!! i was at the turkey rod run in daytona last year over 3000 show cars 1 nice t/a 2 esprit driver/projects/junk 1 decent formula. more 69 camaros than i could count. wife wanted to build a 69 camaro until that show. now working on a 71 formula i have both hoods decisions decisions! thanks for the pics
Old 02-15-2010, 08:40 AM
1973Formula 1973Formula is offline
I have a Shakeula hood. It came on my Formula 350. It also has some hood pin holes. Once you cut the shaker hole, there is no turning back. Definitely looks like an unfixable mod. Maybe it would look better if you turned the shaker toward the front. I have never seen that.
Later-
1972 Formula 400
Old 02-15-2010, 12:38 PM
2manyT/A'S's Avatar
Later-
There is NO hope or future for a W66 hood with a shaker hole cut in it.
The ONLY thing you can do is remove it & sell it to somebody with a black dodge diesel dually.
Let THEM enjoy it & we won't have to look at it anymore.
Old 02-15-2010, 04:45 PM
vidguy's Avatar
vidguy vidguy is offline
Best of Both worlds Dammmit! I still dont hate it.. That Blue car is Sharp.
Looks like it cant make up its mind if its coming or going. :-)
If that hood was closer,... and I had money burning a hole in my pocket,... and a shaker...
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 03-11-2010, 01:34 PM
zman1969's Avatar
zman1969 zman1969 is offline
I remeber seeing some pics of a 73 formula SD here in Dallas that had both since then I thought it was original-rare are you sure they never made any? I didnt care for it. He also had a 74 SD trans am. Man I shoulda grafted formula scoops on to my 72 T/A when I had it- DOH!
Old 03-11-2010, 02:57 PM
cliffhanger's Avatar
cliffhanger cliffhanger is offline
a trans am scoop through a ram air formula hood is completely WRONG on so many levels.
1. ugly. and ik make this paramount.
2. makes the hood to crowded and cluttered with too many obstacles.
3. proves no use of any kind at all:
- ram air functional formula hood does what is should: take in the cold air and force them into the engine thus providing better air flow for a better use of mixture
- trans am (not at all actual shaker) shaker scoop takes in cold air through a different approach by sucking in the air which gets slammed against the windscreen (i dont remember the correct english translation for this word), something to do with pressure, when the 'shaker door' is openened completely. this air is colder then under hood air so again, provides better airmixture possibilities.
EITHER one is MORE then usefull. if you use both, you actually risk the chance of providing a 'tunnel' through the ram air hood, and exit through the t/a shaker. though cold air certainly still will be sucked in, first of all the actual 'pressure' usage in both scoops is lost. in other words, you could just cut a open hole in a base firebird hood and you still get the cold air in.
please note that a formula hood is aerodynamiccaly overall a flaw (even though an entire firebird will not be a aerodynamic prize winner), but it gives the benefit of the ram air function. the trans am shaker wins over formula hood in aerodynamics (offcourse only when installed correctly) due to it's design. combining them together, however, will once again install the negative aerodynamics factor of the formula hood, and increase the amount of obstacles on the hood since the t/a shaker still is a 'bulge' and thus an obstacle, AND the tunneling effect of the ram air formula scoops through the filter and out via the t/a scoop makes another negative aerodynamic factor, since it does not provide any downforce like f.e. a 'tunneling' in the front of a ferrari f50 provides.
to me, combining a formula hood and a trans am hood is like wearing 2 business shirts (not t-shirts) both with a tie. useless, loses the point, wrong at many levels, and in the end: makes you look like a complete and utter tool. like a mullet! - or worse, like KANYE WEST!
4. total disrespect to such a beautifull and flawless designed hood. there is no hood that has such great symbiance with the total design of the entire vehicle. f.e. a 70-73 formula hood looks weird and wrong on any other 2nd gen f-body.
5. rarity factor also makes the formy hood almost 'monumental' (protecting these hoods from bad taste and bad brains by implementing a law against damaging them would save the remainding examples from damage). t/a hoods are almost plenty. formy hoods, RARE. a STRAIGHT, unbent, undamaged, original, fully functional, RAM AIR formula hood is even MORE rare, perhaps even ULTRA-RARE. ripping up such a thing by slamming in a t/a hood is like killing the last dinosaur, dodo or tasmanian tiger.
6. any of the above should be enough to NEVER go into such blasphemous act. taking them all into account would be enough reason to bring out an angry mob with torches and guns and taking law into our own hands to make sure such a thing may never happen again and for correct punishment.
perhaps no longer neccassary but still:
adding a screaming chicken (though nothing wrong imho on 73+ TRANS AMS) to the above is truly disturbing and an direct invitation to lobotomise the perp responsible for such an act (and his thinking).
combining a formy hood with an t/a hood, on a 70-73 t/a, adding a 81 t/a front lower valance spoiler and wheel flares front & rear, adding a screaming chicken on the hood, square mirrors, a 70-73 camaro z/28 rear spoiler, side exhausts, putting 67-69 firebird engine displacement logo's, whilst a 301 oldsmobile engine appears to be under the hood, AND finishing it off with a hood-tacho would make the entire universe collapse and thus the extinction of anything that ever excisted. that includes chuck norris and elvis.
in other words: it may NEVER happen. let's HOPE it never happened. knowing the weird people that roam the earth, it MIGHT already have happened. it would explain global warming, earthquakes and tornados.
please, fix it. we've already lost elvis. bruce lee died under unexplained circumstances. coincidence? you never know....
in final: I know I'm right on the above. you know i'm right. we all know i'm right. now pull up those sleeves and fix any abused formula hood and save the car from it's owner.
Old 03-11-2010, 04:18 PM
Right on, cliffhanger, all custom Trans Ams and Firebirds should be crushed.
Old 03-11-2010, 04:34 PM
hey, i did not say that!
Old 03-11-2010, 04:36 PM
428RA4's Avatar
428RA4 428RA4 is offline
Originally Posted by fbirdinconcord View Post
Thats just wrong. To each his own though.
not just wrong, but retarded.
Old 03-12-2010, 02:16 AM
The Corvette Summer car and Ponch's car both have '71 fender louvers.... every scoop, spoiler and louver ever put on a Firebird all wrapped up in one. Does anyone know if either of those cars was a T/A or a Formula to start with???
Old 03-12-2010, 04:23 AM
Transamric's Avatar
They were real Formulas.
Old 03-12-2010, 07:20 AM
Norwood's Avatar
Norwood Norwood is offline
That someone decided to screw up....
  #38
Old 03-12-2010, 10:18 AM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Heresy!!!! Some custom TAs could be returned to their natural state!!
Also, keep in mind Corvette Summer was about as 70s of a movie as you could get and the guy driving the Formie owned a custom shop. The idea was to radically change the cars into something custom. I'm surprised more wasn't done to that Formula for the purposes of the movie, quite honestly.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
  #39
Old 10-28-2011, 09:36 PM
Was perusing my local CL tonight and found this beaut. It deserves to be immortalized in this thread...
Name:	TA Formula Hood.jpg
  #40
Old 10-29-2011, 03:09 AM
Transamric's Avatar
What? No scoop on the roof?
