#121
I would imagine Bill has a much more correct version. |
#122
Just a thought...If you are going to put the time into making something, why do you make it incorrect when you have the ability to make it correct? So many of the vendors do this and pass it of as correct. See my posts on Pheonix Graphics...THEY ARE GUILTY of this same thing. PLEASE SOMEONE EXPLAIN IT TO ME...sorry about the rant
#123
Hmm, now how did they "paint" across the ridge on the gas take with a stencil overlay? i'm not sure you could get the 'e' to look that good, perhaps it was a spongy stamp. You can see how there is a bit of a smearing upwards.
#124
I think the ink stamp on the gas tanks was stamped on before the sheet metal was stamped into shape. I found this inkstamp on the topside of one of my gas tanks.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
#125
The stamp is on the sheet and is the date of the sheet not the date of the tank. So depending on where on the sheet the tank was stamped from determines where on the tank the stamp might be or if at all.
#126
BJ
1971 GTO 455 HO 4-speed - Cameo White, White Vinyl Top, Jade Green Interior, Ram Air Hood, AC, Honeycombs and 8-track 1974 Formula 455 I Owned in 1975-1976. Now Own Its Twin From Same Dealership |
#127
I concur!
#128
The early 15" Rally II wheels were made up using the same center section as a 14" Rally II. The added 1/2" of "drop center" of the 15" rims used on JWs, KNs and KRs "made up" the difference and gave those wheels their unique appearance. Early big car (Bonneville & Catalina) 15" Rally IIs were also made the same way, however they were 6" wide instead of 7", and also used the big car (5") bolt circle as opposed to the 4 3/4" bolt circle used on the A, F, G, and X-body cars. By 1973, Pontiac tooled up a larger Rally II center section to be used on 15" wheel applications.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 Last edited by Lloyd-TX; 02-22-2010 at 03:23 PM. |
#129
BJ
#130
All this date code discussion and no one has asked about the date code on the Polyglas. Brent, Does your survivor tire have a date code? It should look something like the attached, located very close to the rim.
Many Thanks for posting the pics, Jim |
#131
They should also have a red/orange'ish dot on the outside wall and a burnt orange pencil mark across the outside wall. I have an original in the garage and pic's of this on a 18k mile RAIV, the spare even had a "68" scribed on the inside wall of the spare in this burnt orange pencil marker... Our board member "Matt" knows this car well, he is the one who found it originally and sold it to the guy I visited to photgraph the car. I can't find the orange dot pictures or outside wall scribe marks pictures right now, buthere is a picture of the spare with the same ink pencil/crayon type deal writing...
#132
Brent,
Could you post a picture of both drivers seat belt labels? I have a local printing shop that is going to duplicate the label on a fabric/paper that just like the original. I have the back seat modal # and date code is 46A71 but I need the front belts model # Thank You! Pat |
#133
Bill |
#135
while we are on the subject, i have seen 70 and 71 TAs with the buckle holders on the center console, however with the 72s i have seen some with them and some without (like mine) was that an orderable option ? |
#136
The print shop had a light banner material that is identical to the original label.
Pat |
#138
Yes, please let me know. If your guy printed the labels without the modal # and date I will order a set and add my date as this looks like how it was done originally Thank You! Pat |
#139
Thank you for posting the pictures so quick! Pat |
#140
my understanding on the buckle holders was that they were deleted from the consoles either at the end of the '71 model year or very early in the '72 model year. My 12B built '72 did not have them.
'72 Formula 455HO TH400, Revere Silver, black deluxe '74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe |
