Old 03-08-2010, 10:49 PM
dex dex is offline
Default Body crack at quarter panel
68 gto conv quarter panels crack at the top where the panel meets the back deck. Both sides. I have had them fix three times. Lead the last time not done right. I think wheel hop is the problem what can I do.
Old 03-08-2010, 11:20 PM
Do a search in this forum and the 68-9 GTO forums. It's been discussed a several times.
Mike
former." --Albert Einstein
- Winston Churchill
Old 03-09-2010, 02:51 AM
webfoot's Avatar
webfoot webfoot is offline
Worn out body mounts?
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 03-09-2010, 06:58 AM
I think the general consensus is to weld the seam up solid.
Old 03-09-2010, 09:12 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
I removed all the lead on my 68 , it covers several inches on either side of joint,and found the crack was actually in the quarter panel starting at trunk jamb corner and out along top of panel about an inch or so at about a 45 degree angle . The crack in the paint appeared to be along the seam,but it wasn't. With all lead removed you will see why it's filled and not a seam the way the joint is formed.I welded up the crack and used short strand fiberglass filler on the joint,after welding it solid, and it will most likely crack again but so far so good. You also need to fix that wheel hop problem. I've seen slow motion vid's were you could see the flexing of the frame affecting gap at fender to door on a hrdtp so imagine what it does on a vert. Hop stop bars, adjustable uppers, or fab up your own to correct pinion angle. My $.02 . Leo
Old 03-22-2010, 12:31 AM
PaulatFast PaulatFast is offline
The only way to keep the area from cracking again is to weld a piece of metal in to fill the gap. done this for years... not one issue.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
