Old 04-29-2010, 06:52 PM
afx421's Avatar
afx421 afx421 is offline
is the car tubbed? i dont want to tub mine, if not tubbed, what size is the rear? drum to drum, what size tires wheel back spacing.
1971 ventura 455 12.04 @ 110 w/ crummy 1.69 60 ft - so far!
NHRA super gas licence holder 9.31@145 @ frank hawleys in a 2000 firebird
Old 04-29-2010, 09:35 PM
spartazoo's Avatar
spartazoo spartazoo is offline
Here is what I did...
I put the car up on jack stands and dropped the rear transaxle out of the car. the first thing I bought was the rims and tires that I wanted to use. I set them under the car in position and then measured the distance between the rims. I gave that dimension to the guys building my rear-end and the rest is history.
Everything lined up great when everything came together during assembly.
Kip
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
Old 04-29-2010, 11:38 PM
R 70 Judge's Avatar
Kip
This is the way to do it
James
1970 Trans Am
Old 05-04-2010, 12:17 AM
Poncho_Villa's Avatar
Poncho_Villa Poncho_Villa is offline
Agreed! It is so simple and effective, it's almost like cheating!
This might be a very old thread, but a good one!
Old 05-05-2010, 09:14 PM
beemergary's Avatar
I did like spartazoo. Got 275/50/15s under the 63. Put the tires and wheels under the car with your ride height and do the measuring. Don't forget the thickness of the brake drums also. Ford 9 inch aren't on center so if getting axles made there's two different lenghts. I didn't relize when having axles made you can specify wheel hole pattern. I got tempest front ford back and one spare which only fits the front. Didn't make this mistake when doing the 61 wagon.
Old 05-05-2010, 09:58 PM
spartazoo's Avatar
I had my axles made with 4.5 x 5 bolt pattern to match the front. I also have an extra pair of 15x8 plain steel wheels that the company I ordered from made by mistake. They are just begging for installation on a 63 Catalina SD clone...Born Too Late II? Hummm
Old 05-06-2010, 01:47 PM
grparen grparen is offline
Spartazoo:
My '63 Tempest has 4.5 X 5 up front and 5 X 5 big Pontiac in the rear. However, the 9.5 inch dog dish caps I want to use won't fit on any 5 X 5 wheels. Only 10 1/8 caps fit. Where can I get my axles converted to 4.5 or buy new axles with 4.5 wheel bolt pattern?
BTW, the wheels you had made. They are 4.5 X 5 on 15 X 8? What is the backspace? I may be interested.
Old 05-06-2010, 02:12 PM
Keith Seymore's Avatar
Gary - if you ever get a flat just call me and I'll come gitcha'.
K
'63 LeMans Convertible
'63 Grand Prix
Old 12-22-2010, 07:27 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
Default ???
...... so what is the latest on this car ?? ........
Old 04-29-2010, 11:36 PM
R 70 Judge's Avatar
A '57 Pontiac big car rear is just about the perfect width. I think it's 58" - 59" IIRC. Tom S. has one under his '63 Tempest.
If you want a 9" the Ford 77-81 Granada/Versailles is 58" and from what I've heard here it's pretty close to perfect. Again, it all depends on the wheel width and offset used too.
I have a 28"x12.50" Mickey Thompson ET Street on a 15"x8" Mickey Thompson ET Drag wheel under mine and it's pretty close, but it fits.
James
1970 Trans Am
