Old 06-04-2010, 12:24 AM
lust4speed's Avatar
The alternator I use is a CS130D. I like this alternator because of the open design, it's smaller and a pound or so lighter than the CS144, the electronics are outside on the back away from heat, it has very large bearings, and it has two fans - inside front and inside rear and runs very cool.
Stay away from the CS130. It is a solid case, small bearing, internal regulator, and problem prone. For some reason Delco named their new-from-the-ground-up alternator the CS130D. No parts are interchangeable with the old CS130. My 2008 Duramax diesel came equipped with the CS130D alternator.
The CS144 alternator is also excellent, and it can be had in very high amperages. It is larger and heavier than the CS130D. I know that there are a ton of CS144's in the pick-a-parts and ebay.
On either one, you have to make sure that the proper mounting locations are present to bolt into our old mounting system. Many new alternators have solid mounting points. I avoided the hassle and purchased my 120 amp CS130D new from http://www.qualitypowerauto.com All you have to specify is to have it set up for the V-belt pulley and clocked for a Pontiac. The business is local to me and one of the owners is president of our car club. Wheelspin also uses them for his alternator needs.
Edit: forgot that you would also need the adapter cable that they also carry. Mine is set up as a three-wire and I have a working idiot light and remote voltage sensing.
Mick Batson
Old 06-04-2010, 05:18 AM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
I might be doing this upgrade to the new 62 Cat Wagon. Is this a drop in replacement for an old 3 wire? Is a CS 144 with 3 wires a drop in. The Tempest has a 1 wire and no external voltage regulator.
Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 06-04-2010, 08:59 AM
grandville455's Avatar
Mick All I see is the cs 130? I don't see the cs130d on that site ?
Darby
M/T 275/60 ET SS Drag Radial
Old 06-05-2010, 07:24 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
Mick,the CS 130D can be used with the stock alt brackets?
