Old 09-10-2010, 01:15 PM
HALFWAY's Avatar
HALFWAY HALFWAY is offline
Default Help with removing part on 98 GP
If there is anyone who can help with the removal of the idler pulley assembly I would be gratefull. Here is the link to my questions.
http://forums.maxperformanceinc.com/...d.php?t=644236
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight!
Old 09-10-2010, 01:24 PM
HO 67 BIRD's Avatar
HO 67 BIRD HO 67 BIRD is offline
I would pull the plastic elbow(has o-rings) out first then the o-ringed part out 2nd.Never had to replace the idler assembly but have replaced the pulley and bearing before and replaced plastic elbows(they are famous for leaking).
SEVEN UPS 2.0 TAKING THE THIRD DEGREE ONE STEP FURTHER
2016 1/8 MILE 7.0 @ 100 MPH 406 B&M MINI BLOWER
Old 09-10-2010, 02:13 PM
HALFWAY's Avatar
Thanks, for the info. Does it take much force to remove the plastic elbow. Does it pop straight out or do I "wiggle" it bit to get it loose?
Old 09-10-2010, 02:22 PM
HO 67 BIRD's Avatar
It takes some force.just wiggle and pull.I would also change the dex-cool antifreeze while your at it and replace with green anti freeze .Dex-cool is junk. good luck
www.3800Pro.com is a great site for 3.8 info.
Old 09-10-2010, 02:46 PM
HALFWAY's Avatar
Thanks again, I will give it try.
Old 09-10-2010, 03:18 PM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
Go ahead and get two new coolant elbows. They will break, trust me. They are cheap and can be found in the 'HELP" section of your local auto parts store. I believe Dorman also makes them.
Less said,,,,,,,, Less mended.
Old 09-10-2010, 04:03 PM
HALFWAY's Avatar
Does anyone know how to get the inserts for the heater hoses out of the idler pully assembly.
Old 09-10-2010, 06:49 PM
Larry P's Avatar
Larry P Larry P is offline
Do you mean so the hose will come out? The release tabs are on the sides of the connectors, you can usually spread them just a little, they are brittle, then twisting the hose back and forth will usually free them out so you can pull the hoses out.
Old 09-13-2010, 08:58 AM
HALFWAY's Avatar
all went well, thanks for the info guys.
Old 10-04-2010, 08:17 AM
Cammer-6 Cammer-6 is offline
Use the quick release tool(larger version of the fuel lines) to depress the tabs.
You can buy new clips made by Dorman
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
