Old 12-03-2010, 06:59 PM
njsteve's Avatar
njsteve njsteve is offline
On the 72's the temp sender is a single terminal, button head, sender mounted on the driver's side cylinder head. This is a different location than was used on the 70 and 71 cars which had them mounted on the intake.
Here is a good thread on the exact temp sender unit you need and some tests I did on the repro units on page 2. Turned out that the $6 Wells #TU5 sender was the best, next to a vintage original sender. The current Delco replacements were completely inaccurate as were the LectricLimited units:
http://forums.maxperformanceinc.com/...ht=temp+sender
The three prong unit is the TCS sender that is on the pass side head. It is not designed or calibrated for the gauge and I doubt it will read correctly since it pretty much functions as a temperature-dependant on-off switch for the TCS system.
By the way, don't use teflon tape as it alters the ground resistance to the cylinder head from the sender.
ID:	226782   Click image for larger version
ID:	226783   Click image for larger version
Name:	TCS head location.JPG
ID:	226784   Click image for larger version
Name:	temp sender 3.JPG
